- Lun, 02 May 2011 10:38
#1047005
Hola, voy a comprar una videocam para ponersela a mi clouds fly pero no se por cual decantarme, y la de hobbyking no me apetece mucho por lo de la fecha.
He encontrado estas en ebay:
Mini DV DVR Video Camera Spy Cam SPYCAM HD 1280x960 HOT
General
Width 39mm
Depth 20mm
Height 10mm
Main Features
Image Sensor CMOS
Effective Sensor Resolution 5MP
Image Resolution 2560x1920
Video Resolution 1280 x 960 @ 30 frames per second /
Still Image Format JPEG
Video Format AVI
Audio Format WAV
Lens System Normal
0.5~infinity
Exposure White Blance
Auto
Memory / Storage
External Memory Type MiocroSD
Connections Interface Mini 5 Pin USB
20,46 EUR
Mini Spy Hidden Camera Gum Web Cam AVR Recorder 30FPS
It doesn't own internal memeory
1. Smallest Pin-hole Camera made especially for spy use
2. Latest version 4 in 1 function: video record, sound record, camera, webcam.
3. External Memory: Support 1~8GB TF card (not include memory for this item).
4. High definition video with voice lets
5. Color Video and Audio Recording
6. Video AVI Format 720 x 480 High Resolution
7.Photo JPEG Fomat 1600*1200 pixels
8. Playback video on your PC
9. Easy connection with PC/Laptops, no driver needed
10. Easy to use "One Touch" record button
11. USB Plug & Play Compatible
12. Can be used as USB storage device
13. Built-in rechargeable high volume Lithium-ion Battery
14. Real time record any video and audio evidence instantaneously
15. Dimension: 74 x 21 x 13mm (2.8 x 0.8 x 0.5inches)
11,39 EUR
Mini DV DVR Sports Video Camera MD80 Spy cam 30fps HD
It has small contour design, which does UV spray finishing for the whole body. It is very fashionable and wearable and matches with all kinds of portable tools.
Support PC camera and chatting function.
Support AVI video format.
It can carry out high definition image recording under low illumination.
Support 30 fps for 720*480 and 320*240 video shoot and output.
Support USB1.1 and USB2.0.
Support 8GB T-flash card.(the TF card is not included)
Build-in lithium battery which can make a video more than two hours, the standby time is up to 250 hours.
20-25€ aprox
30FPS CAM Car Key Shade Mini CCD DVR Camcorder HD TP5
•Wireless remote control of your PC up to 33ft. (10m)
•Smallest Pin-hole Camera made especially for spy use
•External Memory: support the TF/Micro SD expansion card from 128MB to 8GB (Not included Memory Card)
•Internal Memory: No
•High definition video with voice lets
•Color Video Recording
•Video AVI Format 720 x 480 High Resolution (30fps)
•Photo JPEG Format 1280 x 960 pixels
•Playback video on your PC
•Easy connection with PC/Laptops, no driver needed
•Easy to use "One Touch" record button
•USB Plug & Play Compatible
•Built-in rechargeable high-capacity Lithium polymer
•Battery Up Time: Approx. 2 Hours
•Real time record any video evidence instantaneously
•Support system: Windows98SE/ME/2000XP/Vista/LINUX2.4 above and automatically distinguish operating system.
•Dimension: 50 x 32 x 13mm
8 € Esta no creo que sirva para nada pero por si acaso... vale le pongo 2.
No me quiero gastar mas de 25€. Graciass.
General
Width 39mm
Depth 20mm
Height 10mm
Main Features
Image Sensor CMOS
Video Format AVI
Audio Format WAV
Lens System Normal
0.5~infinity
Auto
Memory / Storage
20,46 EUR
11,39 EUR
20-25€ aprox
