- Mar, 19 Feb 2008 23:06
#627879
Hola a todos,
A ver si me podeis echar una mano tengo un multiplex Gemini con lo siguiente:
Tengo este Motor:
Motor Brushless HM 281408 1000KV
Type: A2814/8
Dimension:35x36mm
Weight:100g / 3.66 oz
Motor shaft:4mm
KV:1000 RPM
Efficiency:>80%
Working voltage:
Ni-MH (7-10 cells)
Li-Poly(2-3 cells)
Working current:15-25A
Recommended prop:
Ni-MH:7 cells:11x7
Ni-MH:8 cells:10x7
Ni-MH:10 cells:9.5x5
Li-Poly(11.1V):9.5x5
Application:1000-1900g airplanes
Includes:
1 x brushless motor
1 x motor mount with screws
HiModel Static Thrust Real Test Report
Voltage Prop Typical Current(A) Peak Current(A) Typical Thrust(g) Max Thrust(g) RPM/V Internal Resistance(Ω)
11.1V APC 10x5 15 18 1000 1100 500 0.05
11.1V APC 12x6 25 30 1400 1600 408
14.8V APC 10x5 23 27 1500 1700 900
a. The data only represent the results under our testing environment, we are not responsible for any inaccuracy.
b. HiModel copyright reserved, copying or reproducing are prohibited.
Este variador:
Variador 35A Brushless
Tamaño : 45X23X12 mm
Peso : 25g
Corriente continua : 35A
Picos : 45A durante 15 segundos
Voltaje de entrada : 5.5 a 16.8V
Modo Governor
La pregunta es: ¿me servirían estas Baterias?
http://www.rcmart.com/catalog/product_i ... s_id=25737
Tengo este Motor:
Type: A2814/8
Dimension:35x36mm
Motor shaft:4mm
KV:1000 RPM
Efficiency:>80%
Working voltage:
Ni-MH (7-10 cells)
Li-Poly(2-3 cells)
Recommended prop:
Ni-MH:7 cells:11x7
Ni-MH:8 cells:10x7
Includes:
1 x brushless motor
Este variador:
Peso : 25g
Modo Governor
