- Mar, 15 Ene 2013 17:06
#1190990
Hola, buenas tardes
Estoy comiendome el tarro, para construir una Bird dog de 1'80, hace algun tiempo construi una Piper J3, version militar del mismo tamaño, volaba muy bien con un '40 de 1'36CV.
Estoy pensando en construir todas las alas en foam forrando un tercio con balsa y el resto con tela, con eso el avion aguantara mas los trancazos que supongo le voy a dar, yo soy mas de construir que de volar
No se si he elegido bien, pero me he comprado un Aeolian C4250 KV600 Brushless Motor
Specification
Rotational Speed 600 (kv) RPM/V
Continuous Current 50A
Max. Current 60A
Input Voltage 6 - 22.2V
Max. Efficiency 98%
No Load Current 2.5A
Internal Resistance 17m(Omega)
Power 1255W
Motor Weight (Motor only) 229g
Motor Dimensions (Diameter x Length) 42mm x 50mm
Propeller Dimensions 13" x 8"/ 12" x 10"/ 14" x 7"
Input Battery Types NiCd/ Nimh/ Li-po Battery
y estoy por complementarlo con este variador
Aeolian 60A brushless Motor Speed Controller ESC BEC
Specification
Equipped with high-speed, small-sized, multifunctional MCU
Full protection feature including low-voltage protection, over-heat protection, signal lost protection, safe power on protection.
Excellent startup performance, great throttle linear and quick throttle response,excellent low-speed performance.
Max speed: 240,000 RPM (2 poles), 80,000 RPM (6 poles), 40,000 RPM (12 poles).
Individual power circuit for MCU and BEC to improve anti-interference capacity.
The parameters of ESC can be configured via transmitter.
Throttle range can be configured to be compatible with different receivers.
Input voltage: 5.5V-26V (support 2-5S lithium batteries)
Continue current: 60A
Burst current: 80A (within 10 seconds)
Suitable for aircraft Brushless motor
BEC output: 3A/5V (linear)
Weight: 50 g
Que baterias deberia comprarme?
A que potencia corresponden los 1255 wats del electrico? serian 1,7 HP
Specification
Max. Current 60A
Max. Efficiency 98%
Power 1255W
Specification
Weight: 50 g
Juanma
Futaba 7C FASST
Futaba 6EX FASST
Chacal modificado
Pipper L4
Cessna L19 Bird Dog
Messerschmitt Me-410, en diseño
Spitfire IX de Brian Taylor (80%)
SIG Kadet LT-40 modificado
Das Ugly Stik
Trainer 1000 Amperios
Juanma
Futaba 7C FASST
Futaba 6EX FASST
Chacal modificado
Pipper L4
Cessna L19 Bird Dog
Das Ugly Stik
