Por vdevenganza
#1220851
MAS CODIGOS!!!
Turnigy Aerodrive SK3 - 2830-1020kv Brushless Outrunner Motor
http://www.hobbyking.com/buddy.asp?code ... D46926628D
Turnigy AE-25A Brushless ESC
http://www.hobbyking.com/buddy.asp?code ... 87FA0BBF55
Turnigy XR7000 Reciever for Turnigy 4X/6X TX
http://www.hobbyking.com/buddy.asp?code ... 797B6F4697
Turnigy nano-tech 1300mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... A170A262FF
Linkage Stopper D2.1mm (10sets)
http://www.hobbyking.com/buddy.asp?code ... 234AD0692C
Futaba Y Servo Lead 15cm Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 3FC5E1A00D
15CM Servo Lead Extention (Futaba) 26AWG (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 853D7517B4
Por mivion
#1223297
Hola, ahí van unos codigos.
Batería 6v. NiMh LSD 2300
http://www.hobbyking.com/buddy.asp?code ... A23F7ECD35
Lipo Zippy 2s 5000 20C
http://www.hobbyking.com/buddy.asp?code ... CF55E091E3
Turnigy 30A BRUSHED ESC
http://www.hobbyking.com/buddy.asp?code ... 7B8A6EF787
Propeller Adapter (Colet Type Long) 3mm
http://www.hobbyking.com/buddy.asp?code ... 157018D9F7
Hobbyking Multi-Rotor Power Distribution Board (DIY 8 x output PCB)
http://www.hobbyking.com/buddy.asp?code ... 28FD30A23C
Por teammariano
#1223701
unos codigos.
Boscam 5.8Ghz 200mw FPV Wireless AV Tx & Rx Set
http://www.hobbyking.com/buddy.asp?code ... 102062FED6
bbyking Lipo to USB Charging Adapter
http://www.hobbyking.com/buddy.asp?code ... 6E58940C09
Multi-Rotor Roll/Tilt GoPro Hero 2 Camera Mount
http://www.hobbyking.com/buddy.asp?code ... 48A3B1A4F5
ZIPPY Flightmax 3000mAh 3S1P 20C
http://www.hobbyking.com/buddy.asp?code ... C675501386
FrSky DHT 8ch DIY Telemetry Compatible Transmitter Module
http://www.hobbyking.com/buddy.asp?code ... 45EB674730
espero le sirva alguno.
Por Mazinger
#1224861
Por vdevenganza
#1226345
Turnigy AE-30A Brushless ESC
http://www.hobbyking.com/buddy.asp?code ... DD69D77783
Nylon & Pinned Hinge 20x36 (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 80EC011289
Control Horns 16x20mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 8430FEB6F8
Pin Horns L22xW19xH.9 (10sets)
http://www.hobbyking.com/buddy.asp?code ... 11F61A959C
Turnigy 6X FHSS 2.4ghz Transmitter and Reciever (Mode 1)
http://www.hobbyking.com/buddy.asp?code ... 6CC5042FCF
TURNIGY Transmitter Strap
http://www.hobbyking.com/buddy.asp?code ... 4DA47E9FDE
60CM Servo Lead Extention (Futaba) 26AWG (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 21A2A70C5D
Futaba Y Servo Lead 30cm Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 4DE6700C43
Turnigy AE-20A Brushless ESC
http://www.hobbyking.com/buddy.asp?code ... D1D805BF60
http://www.hobbyking.com/buddy.asp?code ... DBCF81B69D
http://www.hobbyking.com/buddy.asp?code ... 2495C0FBF9
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... 041EB877C1
Squadron/Air Command Insignia Various
http://www.hobbyking.com/buddy.asp?code ... 79A731D532
#1229682
Nuevos códigos:
Hobbyking Super Mini Quadcopter Frame with Motors (445mm)
http://www.hobbyking.com/buddy.asp?code ... 7905D675D2
6x3 Propellers (Standard Rotating) (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code ... A7192C6141
6x3R Propellers (Counter Rotating) (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code ... 2631A2807C
HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
http://www.hobbyking.com/buddy.asp?code ... 3799A1817E
TP Slow Fly propeller 11x3.8
http://www.hobbyking.com/buddy.asp?code ... 03CE56C53B
Slow-Cure 30 Min Epoxy Glue 4.5 oz
http://www.hobbyking.com/buddy.asp?code ... 1577060DDB
Prop adapter to suit 4.0mm motor shaft (collet)
http://www.hobbyking.com/buddy.asp?code ... 8342C38606
http://www.hobbyking.com/buddy.asp?code ... 1C039A6E63
http://www.hobbyking.com/buddy.asp?code ... EF5B1ABDA4
Strong Rare-earth Magnets (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 15D6A51855
Mini Tachometer for Ignition Use (30000 RPM max)
http://www.hobbyking.com/buddy.asp?code ... 45BEF2ADC2
Teflon Coupler with clips (22mm Pipe) for Muffler
http://www.hobbyking.com/buddy.asp?code ... 6911D5E5F6
#1231641
TURNIGY Plush 12amp (2A BEC) BESC
http://www.hobbyking.com/buddy.asp?code ... E378E4A3B7
http://www.hobbyking.com/buddy.asp?code ... 9682CE7636
M3 Nylon Nut (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... B4578691F5
M3x8 Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... FBD4569296
5.6mm x 21mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code ... C4681CD444
M3X10 Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 301D5D4CFA
M3x12mm Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... E762CC659F
Walkera 600mAh 1S 20C Lipo Battery Pack (Suits QR Infra X, V120D02S)
http://www.hobbyking.com/buddy.asp?code ... 5A6A695599
GT-Power Voltage Analyzer 3 in 1 2-6S
http://www.hobbyking.com/buddy.asp?code ... D4FAF9D7FE
Alloy Anti-Slip TX Control Sticks Long (Futaba TX Red)
http://www.hobbyking.com/buddy.asp?code ... 8A9A7342DB
Por bonet
#1235823
Códigos válidos hasta el día 28/8/2013.
APC style IC Sport propeller 9x6
http://www.hobbyking.com/buddy.asp?code ... 13E699D27F
5 Pin Molex Connection Lead (Suits Fatshark)
http://www.hobbyking.com/buddy.asp?code ... C387D802DB
JM 6x4 /152.5x102mm propeller (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... BA7B11C0C0
Aluminum Canopy Lock/Hatch
http://www.hobbyking.com/buddy.asp?code ... 053549C80F
#1236818
Nuevos códigos:
Turnigy nano-tech 1600mah 3S 25~50C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... FC47B61A49
H-KING 50A Fixed Wing Brushless Speed Controller
http://www.hobbyking.com/buddy.asp?code ... 0A8E3BF741
Turnigy 1300mAh 3S 25C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... 619354521A
Por Currante
#1239340
Aqui les dejo algunos codigos de descuentos, espero que os sirvan
Turnigy 5A (8-26v) SBEC for Lipo
http://www.hobbyking.com/buddy.asp?code ... 0F1915E734
HK450 size Pinion Gear 3.17mm/11T (Align part # HZ052)
http://www.hobbyking.com/buddy.asp?code ... 83CDE9779B
450 Size Heli Main Gear Set (2pcs)
http://www.hobbyking.com/buddy.asp?code ... 8AD05E340E
HXT900 Replacement Gear Set
http://www.hobbyking.com/buddy.asp?code ... 8048FA2CD8
#1239350
Q450 Glass Fiber Quadcopter Frame 450mm - Integrated PCB Version
http://www.hobbyking.com/buddy.asp?code ... E766A36DEC
UFO Y-4 Micro Multicopter w/2.4GHz Transmitter and Auto-Flip Feature (Mode 2) (RTF)
http://www.hobbyking.com/buddy.asp?code ... 2742EE9772
Hobbyking Slow Stick Brushless Powered Airplane EPO/Carbon Fiber 1160mm (PNF)
http://www.hobbyking.com/buddy.asp?code ... D878162A80
Por san
#1240834
Os dejo aquí otros códigos que os pueden ser útiles. :wink:
ZIPPY Compact 350mAh 2S 25C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... 8C9D0877C3
SF E-Prop 8x3.8 / 203x96.5mm w/ Adapters Black (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... E3E5AB588E
Turnigy 9X 2.4GHz 8Ch Receiver (V2)
http://www.hobbyking.com/buddy.asp?code ... EA9E443C54
Control Rod/ABS Sleeve (1pc/bag)
http://www.hobbyking.com/buddy.asp?code ... 8F99D96BCF
Super Gold Thin Odorless CA Glue 1. oz (Foam Safe)
http://www.hobbyking.com/buddy.asp?code ... D1D291D723
Super Gold Plus Odorless CA Glue 1. oz (Foam Safe)
http://www.hobbyking.com/buddy.asp?code ... 10257DFABB
Hobby King 4.3g / .5kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?code ... 67A793E11E
HobbyKing 12A BlueSeries Brushless Speed Controller
http://www.hobbyking.com/buddy.asp?code ... EEB825EF97
Turnigy FBL100 Main Frame
http://www.hobbyking.com/buddy.asp?code ... 521A45D83E
Landing Gear for Micro Indoor Plane (1pair)
http://www.hobbyking.com/buddy.asp?code ... EB5BE15F50
Super Light Pivot & Round Hinges D2xW8xL24mm (12pcs)
http://www.hobbyking.com/buddy.asp?code ... F01D8DBEDA
Light weight horn set
http://www.hobbyking.com/buddy.asp?code ... 4C8C7BCFD7
Un saludete. :mrgreen:
Por legin37
#1242036
Recubrimientos y algo mas
http://www.hobbyking.com/buddy.asp?code ... 59D1F99888
http://www.hobbyking.com/buddy.asp?code ... 8751628515
http://www.hobbyking.com/buddy.asp?code ... 6B1CB4B5FB
http://www.hobbyking.com/buddy.asp?code ... 390EAA9195
http://www.hobbyking.com/buddy.asp?code ... B7CB2EDAEF
http://www.hobbyking.com/buddy.asp?code ... DA74972168
Description Quantity Unit Price
Covering Film Solid Black (5mtr) 114 (EU warehouse)
Covering Film Solid White (5mtr) 113 (EU warehouse)
Covering Film Solid Mid-Yellow (5mtr) 104 (EU warehouse)
Turnigy 3mm Heat Shrink Tube - BLACK (1mtr) (EU warehouse)
Military Truck Laser Cut Wood Model (KIT) (EU warehouse)
Alloy Clevis for Non Threaded 2mm Control Rod (EU warehouse)
White 16 LED Circular Light Board with Lead (EU warehouse) 1
Por juerwotow
#1243339
Por vdevenganza
#1243845
Turnigy 6X FHSS 2.4ghz Transmitter and Reciever (Mode 1) http://www.hobbyking.com/buddy.asp?code ... 5E1AA5BE25
Turnigy AE-20A Brushless ESC http://www.hobbyking.com/buddy.asp?code ... 7688714FAC
http://www.hobbyking.com/buddy.asp?code ... 9EB47C358C
Control Horns 13.5x16mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 4F1290AD48
Pivot & Round Hinges 2.5x43 (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 0D2773BE21
Pivot & Round Hinges 2.5x48 (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 0CCF26CE9E
Nylon Clevis 1.8x27mm (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 0EB2EDC7A3
Nylon & Pinned Hinge 16x28.5 (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 8E59F89E4E
  • 7
  • 8
  • 9
  • 10
  • 11
  • 13
