- Jue, 26 Mar 2009 21:48
#815252
Voy a comprar un moto-velero y ahora tengo la duda de que emisora comprar..
Una emisora es de hobbycity & hobbyking y la otra de RCLimits.com
La diferencia es una cantidad de dinero superior a 50€.
La de hobbycity:
Spektrum Dx6i Mode2 w/ 6200 Rx [125€]
The 6-channel DX6i uses the same full-range DSM2™ technology found in the Spektrum DX7 and includes an impressive list of programming features for both airplanes and helicopters that are simple to access and use. It comes with the new AR6200 DSM2 6-channel receiver that is robust enough to use in large models yet compact enough fit in many park flyers. The DX6i is also compatible with all existing Spektrum aircraft receivers. Whatever kind of flying you do, the DX6i can be adapted to most any model in your existing collection that requires 6-channels or less.
Key Features
* Full range 2.4GHz DSM2 6-channel radio
* 10-model memory
* ModelMatch
* ServoSync
* Roller/selector user interface
* Attractive and ergonomic design
* Proven DSM2 technology
* Rudder dual-rate
* Large LCD display
* Integrated timer
* Contrast Adjustment
* Dual-speed trim scroll
* Model name and type
* Throttle cut
* Trainer Mode
* Model Copy
* Travel adjustment
* Sub-trim
* Servo monitor
* Dual rate and exponential
* Compatible with any existing DSM and DSM2 receivers
* Airplane Programing Features: Flaps, P-mixes, Dual aileron, V-tail, Delta, Differential
* Heli Programming Features: Gyro adjust, Graphic throttle curve, Graphic pitch curve, P-mixes, Revo mix, Swash type (Normal, and CCPM 120)
* Adjustable stick length
* Direct trim access display
Included.
DX6i system
AR6200 DSM2 reciever
4 x AA batteries
Bind plug
La de RCLimits.Com [185€]
Futaba 6EXA Super 6 channel FM Computer Radio System
with the R127DF receiver and four S3004 standard size ball bearing servos.
This system is designed for the first time modeler that prefers a computer style radio.
Y bueno la tercera opcion es que me digais alguna que ande por ese precio y de calidad se asemeje.. o alomejor superior jaja
GRACIAS POR TODO UN SALUDO!
La de hobbycity:
Key Features
* 10-model memory
* ModelMatch
* ServoSync
* Rudder dual-rate
* Large LCD display
* Integrated timer
* Throttle cut
* Trainer Mode
* Model Copy
* Travel adjustment
* Sub-trim
* Servo monitor
Included.
DX6i system
4 x AA batteries
Bind plug
