- Dom, 03 Abr 2005 16:57
#52807
......siempre hay alguien ¿impresentable? que se empeña en decir lo contrario.
AVISO: Este post es un ¡peñazo! y puede levantar dolor de cabeza. No se admiten reclamaciones.
Aquí tenemos algún ejemplo:
http://64.235.225.26/helicopter/t90077p1/
Los ejemplos, en la red, son incontables.
Aquí:
http://www.rotorworks.net/viewtopic.php ... 935bb960f0
Dicen que:
EMERGENCY SAFETY ALERT
Lithium Battery Fires
Lithium batteries are becoming very popular for powering the control and power systems in our models. This is true because of their very high energy density (amp-hrs/wt. ratio) compared to NiCads or other batteries. With high energy comes increased risk in their use. The, principal, risk is FIRE which can result from improper charging, crash damage, or shorting the batteries. All vendors of these batteries warn their customers of this danger and recommend extreme caution in their use. In spite of this many fires have occurred as a result of the use of Lithium Polymer batteries, resulting in loss of models, automobiles, and other property. Homes and garages and workshops have also burned. A lithium battery fire is very hot (several thousand degrees) and is an excellent initiator for ancillary (resulting) fires. Fire occurs due to contact between Lithium and oxygen in the air. It does not need any other source of ignition, or fuel to start, and burns almost explosively.
These batteries must be used in a manner that precludes ancillary fire. The following is recommended:
1) Store, and charge, in a fireproof container; never in your model.
2) Charge in a protected area devoid of combustibles. Always stand watch over the charging process. Never leave the charging process unattended.
3) In the event of damage from crashes, etc, carefully remove to a safe place for at least a half hour to observe. Physically damaged cells could erupt into flame, and, after sufficient time to ensure safety, should be discarded in accordance with the instructions which came with the batteries. Never attempt to charge a cell with physical damage, regardless of how slight.
4) Always use chargers designed for the specific purpose, preferably having a fixed setting for your particular pack. Many fires occur in using selectable/adjustable chargers improperly set. Never attempt to charge Lithium cells with a charger which is not, specifically, designed for charging Lithium cells. Never use chargers designed for Nickel Cadmium batteries.
5) Use charging systems that monitor and control the charge state of each cell in the pack. Unbalanced cells can lead to disaster if it permits overcharge of a single cell in the pack. If the batteries show any sign of swelling, discontinue charging, and remove them to a safe place outside as they could erupt into flames.
6 )Most important: NEVER PLUG IN A BATTERY AND LEAVE IT TO CHARGE UNATTENDED OVERNIGHT. Serious fires have resulted from this practice.
7) Do not attempt to make your own battery packs from individual cells.
These batteries CANNOT be handled and charged casually such as has been the practice for years with other types of batteries. The consequence of this practice can be very serious resulting in major property damage and/ or personal harm
Safety Committee
Academy of Model Aeronautics
5161 E Memorial Drive
Muncie, IN 47302
Más o menos lo que dice Gonzo, en su página, sobre el cuidado de las lipos:
http://www.rcmaterial.com/LipoManualES.htm
En un post antiguo, Esco dice:
Weterlin, un conocido participante en nuestro foro, dice en otro post:
http://www.helihobby.com/videos/LithiumBattery.wmv
¡Coño! Una caja ignífuga especial para guardar y cargar lipos ¿Porqué será?
Otra:
Aquí también dan un “porrón” de precauciones, las webs con recomendaciones rigurosas, son incontables:
http://www.zagi.com/index.php?main_page=pqs_safety
Y, por si hay alguien que todavía tenga dudas, que mire este link:
http://klaudius.free.fr/lipo.htm
También, evidentemente, es posible que haya algunos incendios de pilas provocados a posta. Pero no creo que el todoterreno, ni los modelos, los hayan quemado adrede.
Copiado de RC Groups, tal cual, de aquí:
http://www.rcgroups.com/forums/showthread.php?t=209187
Lipo Fire Incidents by Cause
Posts that have referenced a lipo cell catching fire have been categorized as to failure cause. This list most certainly does not contain all the incidents and a statistical analysis would be meaningless. It does however show that the warnings presented for lipo cells are not just legaleeze but warnings that should be heeded to prevent possible personal harm and/or property damage.
These first two posts will be updated as data is collected.
Information was gathered from the posts referenced. Please PM me if you see any discrepencies. The listing does not include any of the many 'ballooning only' reports.
FIRE DURING CHARGING:
Operator Error-
9s pack catches fire while being charged at 10s setting. (9)
2s pack catches fire being charged as 3s (10)
2s pack catches fire when charged at 3s setting (13)
2s pack catches fire in plane while charging at 3s setting. (22)
3s pack charged at 4s voltage ignites (27)
2s pack catches fire charged at 3s (30)
2s pack ignites when charged at 10.2V (31)
Overcharged battery (34)
2s pack charged at 11.1V catches fire. (36)
2s pack charged at 3s setting (40)
2s pack charges at 11.1V burns – (44)
2s charged at 11.2V goes off in garage – (47)
2s charged at 3s voltage ignites in garage – (49)
2s charged at 3s ignites in workshop – (52)
Another count problem – Heli burns (57)
Cell count error caused fire – (61, 62)
Pack charged on NiCd setting - (66)
Run Down pack catches fire during charge – (71)
LiPo Burns during charge on 109 charger after mode mis-set (82)
Charging slightly swelled pack causes fire (86)
Li-Ion cells catch fire from charger setting error (88)
Undetermined Cause While Charging
Fire damages garage while charging pack. (7)
1500 3s pack catches fire during 1A , 11.1V initial charge. (1)
2 cell pack ignites while being charged with 2 cell charger. (11)
Car burns when pack being charged in car catches fire. (24)
2s2p pack catches fire in helicopter – possible that charger misread # of cells. (25)
2s pack ignites while on charger set for 2s. (28)
$30,000 damage to house when pack ignites during charging. (no details) (43)
3s pack burns in garage – (35)
3s pack burns at correct settings- (41)
3s pack burns at correct charger settings – (46)
3s 8000mah pack catches fire after 15min – correct settings – (53)
Helicopter and pack burns after 15min charge – (54)
Automatic cell count charger – pack catches fire (55)
Automatic cell count charger – pack catches fire (56)
Lipo rockets across room (58)
Automatic cell count charger – Lipos burn in garage (59)
Battery ignites in car seat during charging (63)
Damaged battery ignites during charge (67)
Pack balloons during charge, burns while under water (68)
11s3p pack burns during charging at correct parameters (70)
Another charging fire – (72)
Helicopter burns when LiPo ignites during charge (73)
Undetermined cause to LiPo fire during charge – (74)
Chopper burns from charging LiPo fire (76)
House fire (81)
3s Pack Ignites burning front of car during charge at correct settings. (83)
FIRE FROM PACK DAMAGE:
Cell poked with exacto knife catches fire- (2)
Dog bites pack, pack catches fire (4)
Lexus burns after pack from crashed plane put in car. (8)
Ballooned pack ignites when punctured. (20)
Repaired pack catches fire when connected to plane. (29)
Pack catches fire after plane crashes. (37)
Pack cut while shrink wrapping (39)
Pack punctured during crash burns. (64)
Plane crashes, pack removed and 10 minutes later burns (65)
Battery pack at 1V ignites while charging (71)
Puffed pack ignites during charging – (77)
Puffed Pack smokes when punctured (79)
Nicked pack catches fire (87)
BATTERY SHORTED FIRES:
Shorted pack catches fire (26)
Pack burns after shorting (15)
Possible Short (38)
Shorted when moved on table – (42)
Pack Shorted putting connector on and burns – (45)
Shorted pack burns hole in BMW seat – (48)
Crash causes 3s pack to short and burn – (50)
Pack ignites sometime after connector shorted for a short time (85)
NO CAUSE DETERMINED:
Multi cell pack catches fire in flight (5)
Possible over discharge (33)
Lipo pack catches fire in car (60)
2s pack starts house fire (84)
OTHER
2s pack connected in series with 3s pack ignites in fireball (78)
References -
1. http://www.rcgroups.com/forums/show...193#post1625193
2. http://www.rcgroups.com/forums/show...0&pagenumber=18
3. http://www.rcgroups.com/forums/show...337#post1531337
4. http://www.rcgroups.com/forums/show...599#post1531599
5. http://www.bayrc.com/boards/viewtopic.php?t=226
6. http://www.rcgroups.com/forums/atta...&postid=1478616
7. http://www.rcgroups.com/forums/show...+fire+explosion
8. http://www.rcgroups.com/forums/show...ight=lexus+fire
9. http://www.rcgroups.com/forums/show...ht=funtana+fire
10. http://www.rcgroups.com/forums/show...ighlight=rocket
11. http://www.ikarus-modellbau.de/ubbt...sb=5&o=&fpart=1
12. http://www.rcgroups.com/forums/show...light=lipo+fire
13. http://www.rcgroups.com/forums/show...threadid=160086
14. http://www.rcgroups.com/forums/show...threadid=160079
15. http://www.rcgroups.com/forums/show...threadid=160551
16. http://www.rcgroups.com/forums/show...light=lipo+fire
17. http://www.rcgroups.com/forums/show...light=lipo+fire
18. http://www.rcgroups.com/forums/show...light=lipo+fire
19. http://www.rcgroups.com/forums/show...light=lipo+fire
20. http://www.rcgroups.com/forums/show...light=lipo+fire
21. http://www.rcgroups.com/forums/show...light=lipo+fire
22. http://www.rcgroups.com/forums/show...light=lipo+fire
23. http://www.rcgroups.com/forums/show...6402#post806402
24. http://www.hornet-heli.com/ubb/Forum3/HTML/003428.html
25. http://www.rcgroups.com/forums/show...light=explosion
26. http://www.rcgroups.com/forums/show...595#post1243595
27. http://www.rcgroups.com/forums/show...890#post1571890
28. http://www.rcgroups.com/forums/show...630#post1581630
29. http://www.rcuniverse.com/forum/fb....9325&tostyle=tm
30. http://www.rcgroups.com/forums/show...4129#post844129
31. http://www.rcgroups.com/forums/show...429#post1553429
32. http://www.rcgroups.com/forums/show...165#post1658165
http://www.rcgroups.com/forums/show...threadid=185530
33. http://www.rcgroups.com/forums/show...734#post1699734
34. http://www.rcgroups.com/forums/show...091#post1731091
http://www.rcgroups.com/forums/show...915#post1731915
35. http://www.rcuniverse.com/forum/fb....6352&tostyle=tm
36. http://members.jcom.home.ne.jp/4223...r%20trouble.htm
http://www.rcgroups.com/forums/show...331#post1761331
Charging crashed pack caused pack unbalance problems - http://www.rcgroups.com/forums/show...503#post1767503
37. Pack catches on fire after crash - http://www.rcgroups.com/forums/show...434#post1779434
38. Possible short – undamaged pack catches fire -http://www.rcgroups.com/forums/showthre ... ost1810304
39. Battery shorts and burns during shrink wrapping - http://www.rcgroups.com/forums/show...608#post1399608
Lipo Fire Video’s
http://www.rcgroups.com/forums/show...715#post1394715
http://www.rcstuff.us/battery/lipo/lipo_DNA.html
Threads they came from:
http://www.rcgroups.com/forums/show...lipo+fire+video
http://www.rcgroups.com/forums/show...15&pagenumber=1
(40) Battery catches fire, wrong charging voltage - http://www.rcgroups.com/forums/show...922#post1898922
(41) First charge of pack - http://www.rcgroups.com/forums/show...threadid=180434
(42) Pack shorted on bench - http://www.rcgroups.com/forums/show...threadid=206095
(43) $30,000 house damage – charger error - http://www.rcgroups.com/forums/show...790#post1816790
(44) 2s charged at 11.1V burns - http://www.rcgroups.com/forums/show...047#post1844047
(45) Pack Shorted putting connector on and burns - http://www.rcgroups.com/forums/show...threadid=209532
(46) 3s Pack burns at correct charger settings - http://www.rcgroups.com/forums/show...threadid=209767
Picture of burned bench – German site - http://www.modellflugjugend.de/archiv/user/lipo2.jpg
(47) 2s charged at 3s goes boom in garage - http://www.rcgroups.com/forums/show...threadid=100803
(48) Shorted pack burns hole in BMW seat - http://www.rcgroups.com/forums/show...486#post1199486
(49) 2s charged as 3s ignites in house - http://www.rcgroups.com/forums/show...ighlight=rocket
(50) Crash causes 3s to short and burn
http://www.rcgroups.com/forums/show...182#post1863182
(52) 2s charging at 3s causes fire in garage -
http://www.runryder.com/helicopter/...light=fire+lipo
(53) 8000 3s pack catches fire at correct settings -
(54) Pack catches fire after charging for 15 min -
http://www.rotory.com/ubbthreads/sh...o=&fpart=1&vc=1
(55) Pack catches fire using automatic charger - http://www.rcgroups.com/forums/show...26&postcount=15
(56) Pack catches fire using automatic charger -
http://www.rcgroups.com/forums/show...446&postcount=1
(57) Helicopter fire - http://runryder.com/helicopter/t82226/?goto=newpost
(58) LiIon pack rockets across room: http://www.rcgroups.com/forums/show...76&postcount=11
(59) Dented Pack Catches fire - http://www.rcgroups.com/forums/show...656&postcount=3
(60) Lipo in closed car catches fire - http://www.rcgroups.com/forums/showthread.php?t=241627
(61) Wrong cell count fire - http://www.rcgroups.com/forums/show...797&postcount=3
(62) Wrong cell count fire – http://www.rcgroups.com/forums/show...326&postcount=1
(63) Battery catches fire in car seat while charging - http://www.rcgroups.com/forums/showthread.php?t=248194
(64) Battery catches fire when plane crashes - http://www.rcgroups.com/forums/showthread.php?t=256098
(65) Battery catches fire after crash: http://www.rcgroups.com/forums/show...97&postcount=12
(66) Battery ignites in under 10min on charger - http://www.rcgroups.com/forums/show...659&postcount=1
(67) Damaged battery catches fire during charging - http://www.rcgroups.com/forums/show...234&postcount=5
(68) LiPo Pack catches fire even tho immersed in salt water - http://www.rcgroups.com/forums/showthread.php?t=261922
(69) Lipo ignition causes house fire - http://www.rcgroups.com/forums/show...250&postcount=4
(70) Pack catches fire for no apparent reason during charge - http://www.rcgroups.com/forums/show...11&postcount=34
(71) Pack at 1V charged and catches fire - http://www.rcgroups.com/forums/showthread.php?t=263600
(72) Battery catches fire during charging - http://www.rcgroups.com/forums/show...421&postcount=1
(73) Helicopter burns - http://www.rcgroups.com/forums/showthread.php?t=266337
(74) 3s Pack ignites during charge - http://www.rcgroups.com/forums/showthread.php?t=266875
(75) House fire reported in Belgium - http://www.rcgroups.com/forums/show...31&postcount=24 CHECK OUT
(76) Plane burns during charge - http://www.rcgroups.com/forums/show...05&postcount=47
(77) Puffed pack ignites during charging - http://www.rcgroups.com/forums/show...964#post2560964
(78) 2s pack connected in parallel to 3s pack ignites - http://www.rcgroups.com/forums/showthread.php?t=274028
(79) Ballooned Pack Burns when punchured - http://www.rcgroups.com/forums/showthread.php?t=274557
(80) 7s pack catches fire during flight - http://www.rcgroups.com/forums/showthread.php?t=296507
(81) House fire – 3rd story burns - http://runryder.com/helicopter/t145397p1/
(82) Lipo catchs fire during charge on 109 charger. http://www.rcgroups.com/forums/showthread.php?t=307806
(83) 3s Lipo catches fire at correct settings. http://rcgroups.com/gallery/showpho...&cat=500&page=1
(84) 2s pack starts house fire- reason unknown - http://www.rcgroups.com/forums/showthread.php?t=311323
(85) Pack catches fire after a short short - http://www.rcgroups.com/forums/show...213#post3044752
(86) Charging slightly swelled pack causes fire - http://www.rcgroups.com/forums/show...077&postcount=4
(87) Nicked cell catches fire - http://www.rcuniverse.com/forum/LiP.../tm.htm#2366986
(88) Li Ion cells ignite from charging mistake -
http://www.rcuniverse.com/forum/LiP.../tm.htm#2427714
CONCLUSION:
Yo, desde luego, no quiero ser alarmista, pero…… “algo tiene el agua cuando la bendicen”.
Y, ¿Porqué darán tantas precauciones a tener en cuenta, si resulta que no tienen peligro?.
Que conste, que yo no pongo nada de mi cosecha, lo único que he hecho es un pequeño recorrido por la red, y visto lo visto, que cada uno se aplique la “cataplasma” donde le duela.
También quiero decir que soy usuario de lipos, y de momento, sin ningún problema, pero no por eso, me creo vacunado contra cualquier problema.
Seguramente…… ¡ESTAN TODOS LOCOS!, y no saben lo que dicen, o exageran, o es que lo han soñado, o les gusta asustar.
J.Puente
Aquí:
Dicen que:
Safety Committee
Muncie, IN 47302
Dando a entender que “NO PASA NADA” aunque reconociendo implícitamente, y entre lineas, que “hay que andarse con cuidado”. ¿Quién no se ha equivocado alguna vez al programar la carga en un cargador?Es imprescindible cargar las baterías con un cargador específico para lipo, es importantísimo equilibrar los elementos de tanto en tanto, sin perder el sueño. Cualquier descuido en estos sentidos se va a traducir en falta de rendimiento, de mucho a todo. Solo hay dos formas de hacerlas explotar y arder.
1ª- El cortocircuito, estas baterías no tienen memoria, la razón es que su resistencia interna es insignificante, cuando se produce un cortocircuito y hasta que empiezan a tener limitaciones de corriente químicas, la corriente que son capaces de dar son INMENSAS, incendio garantizado.
2ª- Cargarlas totalmente pasadas de tensión y de corriente, tensión entorno a 5V por elemento y corriente sobrada para que no se limite, en este caso cuando se inflan lo hacen con un tiempo suficiente para reaccionar.
Por lo demás, desilusión porque había preparado todo para ver como explotaban pero no es nada fácil, le preguntare a lo guiris como lo hicieron.
Aquí tenéis una peli con algunas recomendaciones. Evidentemente el incendio está provocado a posta, pero………,las recomendaciones son las de siempre, por algo será.Por esas fechas me llegó un nuevo pack 3S de KOKAM 910 de descarga constante 15C para mi Piccolo. Pack ya montado. Lo preparé para el uso. Volé con él 2 veces, unos 10 minutos en total. Marché para casa. Lo guardé en mi pote ignífugo por si....
Al día siguiente lo cojo para recargarlo. Aparentemente el pack estaba perfecto. Ni la más mínima sensación de hinchado ni nada similar. Cuando lo tengo en la mano sin saber por qué lanza un fogonazo con un humo intenso como si de un cohete se tratase y con un olor intenso que me dejo casi grogui. Tiré el pack rapidamente y dejó de humear.
El pack tenía una de las conexiones quemadas, una esquina. Nada hinchado. Así siguió 10 días al cabo de los cuales comenzó a inflarse un núcleo. Lo he desechado en su totalidad.
Con esta experiencia entendereis que dejase de lado un BOMBA como la que preparaba para el Mikado. Me he hecho con un pack NiMh Sanyo 3600 de 20 núcleos. Me encuentro confiado con él. Vuela menos tiempo pero me encuentro seguro que eso para mi vale TODO.
Tuve mala suerte....? Es posible. Pero de momento no quiero tentarla más. Las Li-pos que utilizamos han nacido para usos industriales, no para el hobby, y así lo indican sus fabricantes en las indicaciones de las baterías. Espero que pronto mejoren la seguridad en estas fantásticas baterías, vistas desde la potencia que entregan.
Otra:
Operator Error-
House fire (81)
Possible Short (38)
OTHER
References -
Lipo Fire Video’s
CONCLUSION:
J.Puente
Última edición por J.Puente el Dom, 03 Abr 2005 18:06, editado 1 vez en total.
