Por Dmauri82
#1202447
He adquirido un nuevo variador de la modelo AEO Power series ESC 30A.
Tengo que programarlo para activar el freno motor ya que llevo un velero.
Caracteristicas de mi avion:
Bateria: 7.4v 1500A
Variador: 30A
Motor: 1440KV GT2210/11
Helice: 9,2x7
600gr en vuelo
1500 envergadura
El problema es que no se que modo de todos los siguientes tengo que activar para las caracteristicas de mi avion y con freno motor activado:
Function 1. beep setup of the protection of low voltage cutoff for 2 Li-poly batteries. The low cutoff voltage is 6V
Function 2. beep beep setup of low voltage cutoff protection for 3 Li-poly batteries, the cutoff voltage is 9V
Function 3 beep beep beep setup of low voltage cutoff protection for 4 Li-poly batteries, the cutoff voltage is 12V.
Function 4 beep beep beep beep setup of low voltage cutoff protection for 5 Li-poly batteries, the cutoff voltage is 15V.
Function 5 beep beep beep beep beep setup of low voltage cutoff protection and can automatically detect the voltage when it falls to the 80% of the starting run voltage.
Function 6 beep beep beep beep beep beep setup of low voltage cutoff protection and can automatically detect the voltage when it falls to the 72% of the starting run voltage.
Function 7 beep beep beep beep beep beep beep setup of low voltage cutoff protection and can automatically detect the voltage when it falls to the 65% of the starting run voltage.
Function 8 beep beep beep beep beep beep beep beep setup of low voltage cutoff protection and can automatically detect the voltage when it falls to the 55% of the starting run voltage.
Function 9 beep beep beep beep beep beep beep beep beep (9 sounds) setup of the Positive and Negative Turn of motor (this function can eliminating worry from connecting the ESC with motor)
Function 10 beep beep beep beep beep beep beep beep beep beep (10 sounds) setup of brake mode, this is a function that can be switched between the brake and anti-brake (when the throttle stick is shut off, the brake function can be realized via Circuit Simulation to avoid the motor is driven by propeller, especially useful for airplane with fold propeller.)
Function 11 beep beep beep beep beep beep beep beep beep beep beep (sounds 11) setup of speeding up, speeding up rapidly (linear variation of motor speeding up can be set up, especially useful to expert flyer)
Function 12 sounds 12 setup of speeding up, normal speeding up.
Function 13 sounds 13 setup of speeding up, slow speeding up
Function 14 sounds 14 setup of PWM mode, 8KHZ (the frequency of ESC can be set up, and brushless motor can reach its max efficiency)
Function 15 sounds 15 setup of PWM mode, 16KHZ
Function 16 sounds 16 setup of PWM mode 32KHZ
Por chito
#1202462
Hola,la funcion que tienes que activar es la 10.
Slds...
