- Vie, 18 Abr 2008 21:03
#657647
Conoce alguien estos servos?
Specktrum DX821. También los encontré por internet bajo el nombre Maxwell 821MG
1. Carbon nylon gear
2. curve gear with smooth.
3. Double M9.6 ball bearing (si-oil)
4. 3 pole strong torque of motor with low signal affect and success get CE
certification.
5. Rubber fitting case for waterproof
6. Same with Futaba 25 tooth spline
7. Geavy duty servo case
Weight: 47 grams / 1.66 oz.
Dimensions: 40.5 x 20 x 38.5 mm / 1.60 x 0.78 x 1.54 in.
Torque At 4.8V: 6.4kg-cm , 89 oz-in
Torque At 6.0V: 7.2kg-cm , 109 oz-in
Speed At 4.8V: 0.13 sec / 60° at no load
Speed At 6.0V: 0.10 sec / 60° at no load
Motor Type: Double magnetic motor
Wire Info Brown Wire = Battery Negative
Red Wire = Battery Positive
Orange Wire = Signal
certification.
