- Lun, 07 Mar 2005 20:23
#44401
Para el motor permax 400 BB que pienso montar en un easy, ¿ que helice me aconsejais para ponerlo directo, sin reductora?.
Especificación del motor:
Permax 400 BB # 33 2537 The high-performance 400-class motor for small model aircraft. Also a good “hot” motor for 400- size ducted fan units.
Special features:
• External brush gear
• 3.2 mm Ø shaft
• Ballraced
For propellers approx. 5 x 4” to 6 x 3”
Specification:
Dimensions: 29 Ø x 50 mm
Weight: 104 g
No-load speed: 21,700 rpm
Current drain:
No-load 1.5 A
Maximum 23 A
At max. efficiency: 10.5 A
Shaft Ø: 3.2 mm
Direction of rotation,
“+” to red: right
Typical operating voltage: 7 - 10 V
Max. temperature: 80°C
Un saludo a todos.
Special features:
• 3.2 mm Ø shaft
• Ballraced
Specification:
Weight: 104 g
Current drain:
No-load 1.5 A
Maximum 23 A
Shaft Ø: 3.2 mm
“+” to red: right
Un saludo a todos.
