Por bonet
#1107243
Gracias a los códigos de los post anteriores y añado ahora los míos, válidos hasta el 20 de enero.
set brazos Futaba
http://www.hobbyking.com/buddy.asp?code ... 7C996B2AB0
alargos 15cm JR
http://www.hobbyking.com/buddy.asp?code ... 9AB6EC6714
depósito 360cc
http://www.hobbyking.com/buddy.asp?code ... E778BBA178
anillos topes ruedas d.4
http://www.hobbyking.com/buddy.asp?code ... 444911B52F
brazos servo carbono
http://www.hobbyking.com/buddy.asp?code ... 8F00E1AB21
Por Tony_S
#1108264
Válidos hasta 23/1/12
FrSky DF 2.4Ghz Combo Pack for Futaba w/ Module & RX
http://www.hobbyking.com/hobbyking/stor ... duct=14354
De $53,30 a $45,67
http://www.hobbyking.com/buddy.asp?code ... 66F214FCA5
FrSky Telemetry Reciever upgrade USB/Serial
http://www.hobbyking.com/hobbyking/stor ... duct=16672
De $3,98 a $3,70
http://www.hobbyking.com/buddy.asp?code ... 22A45E044E
Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g
http://www.hobbyking.com/hobbyking/stor ... oduct=9392
De $4,99 a $4,48
http://www.hobbyking.com/buddy.asp?code ... 017886DE57
Charge Cable w/ Male XT60 <-> 4mm Banana plug
http://www.hobbyking.com/hobbyking/stor ... duct=10266
De $2,49 a $2,03
http://www.hobbyking.com/buddy.asp?code ... B78FD756C7
Male XT60 <-> Female T-Connector (1pc/bag)
http://www.hobbyking.com/hobbyking/stor ... duct=14543
De $1,07 a $0,81
http://www.hobbyking.com/buddy.asp?code ... 638D2A95CD
MEGA-ADAPTER. Connect almost anything to anything!
http://www.hobbyking.com/hobbyking/stor ... duct=11756
De $4,41 a $4,10
http://www.hobbyking.com/buddy.asp?code ... 2960DD8306
Clear Foam Glue (Medium Cure) - Large 100ml
http://www.hobbyking.com/hobbyking/stor ... duct=17535
De $2,49 a $2,36
http://www.hobbyking.com/buddy.asp?code ... 1F2CF39234
Male T-Connector <-> Female XT-60 (1pc/bag)
http://www.hobbyking.com/hobbyking/stor ... duct=14544
De $1,15 a $0,87
http://www.hobbyking.com/buddy.asp?code ... 5B4FBC3A9E
Female Tamiya <-> Male XT60 (3pcs/bag)
http://www.hobbyking.com/hobbyking/stor ... duct=10257
De $2,63 a $1,95
http://www.hobbyking.com/buddy.asp?code ... 274CE99CEB
Por Antguardia
#1108744
Nuevos códigos de descuento de HOBBYKING
-Master Airscrew propeller 9x6
http://www.hobbyking.com/buddy.asp?code ... 3C16D86D2B
-Master Airscrew propeller 12x6
http://www.hobbyking.com/buddy.asp?code ... 79CF5AC222
-XR Type B Beechwood 3D/SF Propeller 11x7
http://www.hobbyking.com/buddy.asp?code ... 3DBF7ED26F
-APC style propeller 10x5-E
http://www.hobbyking.com/buddy.asp?code ... 778F86CB8F
-Turnigy nano-tech 460mah 3S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... 96CBC0CE43
-XT60 Male w/ 12AWG Silicon Wire 10cm (5pcs/b
http://www.hobbyking.com/buddy.asp?code ... B7E7458070
-EC3 plugs (10pairs/set)
http://www.hobbyking.com/buddy.asp?code ... E3AE76BDA8
Por Antguardia
#1108749
Os lo dejo tambien con las imágenes
Extra Codes, You can save 17.4% for all of this products ! Codes from RC-Buddy.com
Savings: 30.62 % / $0.64
Price after: $1.45
Weight: 19 g
Savings: 38.21 % / $1.41
Price after: $2.28
Weight: 47 g
Savings: 27.39 % / $0.86
Price after: $2.28
Weight: 27 g
Savings: 17.57 % / $0.13
Price after: $0.61
Weight: 35 g
Savings: 4.96 % / $0.32
Price after: $6.13
Weight: 89 g
XT60 Male w/ 12AWG Silicon Wire 10cm (5pcs/bag)
Savings: 14.2 % / $0.74
Price after: $4.47
Weight: 70 g
Savings: 9.51 % / $0.47
Price after: $4.47
Weight: 49 g
Por Jarobaina
#1108984
Hola, hoy he realizado otra compra en HK y pongo los link de descuento.
Lithium Polymer Charge Pack 25x33cm JUMBO Sack
Enlace Dto. http://www.hobbyking.com/buddy.asp?code ... 334B60EC61
Precio: $2.67 Descuento: $0.13 Precio Final: $2.54
X-BLADE Spare SK-5 Steel blades (10pcs/set)
Enlace Dto. http://www.hobbyking.com/buddy.asp?code ... 99CC85C3A2
Precio: $0.99 Descuento: $0.63 Precio Final: $0.36
ZIPPY Flightmax 5000mAh 3S1P 20C
Enlace Dto. http://www.hobbyking.com/buddy.asp?code ... 97FA36FC33
Precio: $26.72 Descuento: $4.31 Precio Final: $22.41
Rhino 2620mAh 3S 11.1v Low-Discharge Transmitter Lipoly Pack
Enlace Dto. http://www.hobbyking.com/buddy.asp?code ... 37A89DF936
Precio: $14.95 Descuento: $1.91 Precio Final: $13.04
GWS Fail-Safe
Enlace Dto. http://www.hobbyking.com/buddy.asp?code ... C377E9E508
Precio: $11.68 Descuento: $0.83 Precio Final: $10.85
Por coyotefer
#1114848
Hola, siento llegar tarde a este hilo y además a preguntar, pero es que tengo curiosidad..yo suelo hacer las compras para varios amigos..al final de las compras me dice algo así como que tengo acumulado por ejemplo un decuento de 10 dólares que yo interpreto que me lo pueden descontar en cualquier compra pero de los cupones etc no se de que habláis..pincho vuestros enlaces y voy directamente al producto de H.K..sin más...la verdad que no me entero ..alguien le importaría explicarmelo pleasse?? así yo tambien podré poner esas cosas si es que me corresponden al hacer las compras..muchas gracias de antemano..
Por Perseo
#1114852
Hola Coyotefer,
Cuando pinchas el enlace que nosotros ponemos vas directamente al producto pero el precio lleva una rebaja, por ejemplo el que yo he puesto es un descuento de 3,49$ en esa batería, si tu buscas la batería en hobbyking sin usar el enlace te sale esos dolares mas cara.
Ahora como se consiguen los descuentos: cuando compras veras que si abres el pedido en hobbyking algunos de los productos que has comprado tienen un icono a la derecha parecido a unas caras pues pinchas ahí y es el enlace con descuento de ese producto.
Espero haberte ayudado.
Por coyotefer
#1114890
gracias perseo..voy a echar un vistazo a lo que me dices y si se puede tambien se contribuye..no es raro que vuelva preguntando algo ehh..pero hay veces que soy un zoquete para entender las cosas más simples..saludos..
Por coyotefer
#1114895
por el momento no he dado con la cuestion ehh..me sale el mismo precio..voy a fijarme mejor..http://www.hobbyking.com/hobbyking/stor ... _Pack.html este es el precio que me sale oficialmente..
Por coyotefer
#1114896
al identificarme me sale el precio de 46,94 no me atrevo a poner el enlace porque aparezco con mi clave abierta..vaya rollo no??
Por Perseo
#1114898
Creo que te sale el mismo precio porque no has entrado primero en hobbyking con tu usuario y contraseña.
Yo si lo hago sin logearme me sale el mismo precio ahora si lo hago logeado me sale el descuento.
Y pregunta lo que necesites que para eso estamos.
Por Perseo
#1114903
Por cierto esos códigos de descuento los da hobbyking para que se los des a tus amigos y compañeros y aplica un descuento a quien lo usa y otro a quien lo da.
Por coyotefer
#1114904
Por Perseo
#1114954
Esos mismo son, si te fijas solo se aplia el descuento cuando estas logeado.
Por Tio Aquiles
#1115020
Por Matte
#1115588
Saludos!
Tengo unos codigos de descuento de HK, igual a alguno os interesan:
Adaptador hélice de 2,3mm a 4,7mm
http://www.hobbyking.com/buddy.asp?code ... F5E6CB6765
Hélice 6x4E, ideal para funjet y similares:
http://www.hobbyking.com/buddy.asp?code ... D2623ED8F3
Variador de 25A max
http://www.hobbyking.com/buddy.asp?code ... BD2C8009E6
Hélice tripala 6x4
http://www.hobbyking.com/buddy.asp?code ... 3F64BE1AA8
A ver si os sirve alguno.
Los descuentos duran 14 dias desde hoy!
Por Jarobaina
#1118799
iMAX Software Kit.
http://www.hobbyking.com/buddy.asp?code ... A3B23198BC
Temperature Sensor w/ Futaba plug for chargers
http://www.hobbyking.com/buddy.asp?code ... 7D54BDDA11
JST-XH 3S Wire Extension 20cm (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 0837FD47C4
XT60 Harness for 2 Packs in Parallel (1pc)
http://www.hobbyking.com/buddy.asp?code ... 182BD28358
JST-XH 2S Wire Extension 20cm (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 531CC4EF03
Nylon T-Connectors 10 Pairs (20pc)
http://www.hobbyking.com/buddy.asp?code ... 9C90708A9F
MPX Connector Male/Female (10pairs/set)
http://www.hobbyking.com/buddy.asp?code ... 122B69FE0A
Female XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/buddy.asp?code ... 7DD97A91BC
Cyanoacrylate (Super Glue) Single Pack
http://www.hobbyking.com/buddy.asp?code ... FB71AC9259
HobbyKing Super Glue CA (50g / 1.7oz) Thick
http://www.hobbyking.com/buddy.asp?code ... 74C4450665
Nylon & Pinned Hinge 16x28.5 (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 3B51DAEE78
Control Horns 13.5x16mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 52F2223C31
Control Horns 16x20mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 35C63CEFE6
JR Y Servo Lead 15CM Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 1E86D1FD14
Por rompeola
#1119082
hay pongo estos:
Rhino 610mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?code ... 258DD5B447
http://www.hobbyking.com/buddy.asp?code ... 043A28337B
Polyquest 1600mAh 2S1P Receiver Pack
http://www.hobbyking.com/buddy.asp?code ... D81A557E71
Battery Tape (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 41B5529BDB
Solo PRO 100 3G Flybarless 3D Mirco Helicopt
http://www.hobbyking.com/buddy.asp?code ... 90FA496FB1
Turnigy nano-tech 750mah 1S 35~70C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... 3A93C8796D
Por bonet
#1119675
Gracias por los códigos anteriores, pero ahora solo me deja poner 2 por pedido.
Añado los míos.
Validos hasta el 29-2-2012.
Mezclador, servos de cola en V o alas tipo zagui. TURNIGY V-Tail Mixer. Ultra-small
http://www.hobbyking.com/buddy.asp?code ... 56C8C639A1
Hélice para eléctrico JM 6x4 /152.5x102mm propeller (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... AE9EC53F6D
Servo Turnigy MG90S Metal Gear Servo 1.8kg / 13.4g
http://www.hobbyking.com/buddy.asp?code ... E57E2A47E7
Hélice para eléctrico, APC style propeller 11x5.5-E
http://www.hobbyking.com/buddy.asp?code ... 56C25BA34F
Filtro motor glow, Turnigy Compact Re-buildable Fuel Filter
http://www.hobbyking.com/buddy.asp?code ... 5F29723E70
Multi-destornillador del MacGiver, Turnigy 6 in 1 Multi Tool - Flat/Phillip/Hex.
http://www.hobbyking.com/buddy.asp?code ... AC18AB0574
Por Tony_S
#1120256
Válidos hasta 2/marzo/2012:
GPS-01 FrSky GPS-01 Telemetry GPS Module
http://www.hobbyking.com/buddy.asp?code ... 07E772319C
$ 35,70
FLD-02 FrSky FLD-02 Telemetry Display Screen
http://www.hobbyking.com/buddy.asp?code ... 90316D1297
$ 19,97
TEMS-01 FrSky TEMS-01 Telemetry Temperature Sensor
http://www.hobbyking.com/buddy.asp?code ... 10B95EC3BA
$ 2,96
TAS-01 FrSky TAS-01 Telemetry Triaxial Acceleration
http://www.hobbyking.com/buddy.asp?code ... 8118DB6340
$ 6,43
D-Buzzer Hobby King Discovery Buzzer
http://www.hobbyking.com/buddy.asp?code ... 1153C5F245
$ 2,54
RB70A-BTO HobbyKing Red Brick 70A ESC
http://www.hobbyking.com/buddy.asp?code ... 248EE04C10
$ 17,42
FSH-01 FrSky FSH-01 Telemetry Sensor Hub
http://www.hobbyking.com/buddy.asp?code ... F7EEB59780
$ 13,92
Por SuaiTeam
#1122590
Código para GWS Servo Tester MT-1 w/ Manual-Auto select.
VÁLIDO HASTA 10 MARZO 2012
http://www.hobbyking.com/buddy.asp?code ... CC984C8BDE
  • 2
  • 3
  • 4
  • 5
  • 13
