Por patalete
#1125767
Validos hasta 20 marzo.
Debes estar registrado y logueado en tu cuenta de HK para obtener el descuento.
Body clips A (10pc) - 110BS Save US$: 0.14
Hobby King GT-2 2.4Ghz Receiver 3Ch Save US$: 0.37
Ultra Thin Foam Glue 40ml Save US$: 0.89
HXT500 5g / .8kg / .10sec Micro Servo Save US$: 0.44
USBasp AVR Programming Device for ATMEL proccessors Save US$: 0.77
Turnigy Teflon Coated Wire 36AWG (1mtr) Black Save US$: 0.36
Turnigy Compact Re-buildable Fuel Filter Save US$: 0.49
TURNIGY Voltage Protector Save US$: 1.38
Strong Rare-Earth Button Magnets (10pcs/set) Save US$: 0.90
Turnigy Teflon Coated Wire 36AWG (1mtr) Red Save US$: 0.36
Por Vallekano
#1126502
Aquí tengo los míos:
Spare Rubber Ring for Prop Saver (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 8ECF7CB29A
Turnigy Pure-Silicone Wire 18AWG (1mtr) Red
http://www.hobbyking.com/buddy.asp?code ... 4AE355A289
Turnigy Pure-Silicone Wire 18AWG (1mtr) Black
http://www.hobbyking.com/buddy.asp?code ... 76E752A055
M3 x 20mm Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 20377E94C5
M3 x 12mm Nylon Screws (10pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 000B6D5B7F
Socket Head Bolt 3x14mm (10 pack)
http://www.hobbyking.com/buddy.asp?code ... E71BE09D54
Socket Head Bolt 3x20mm (10 pack)
http://www.hobbyking.com/buddy.asp?code ... F120986A0D
Hex locknuts M4 10pc
http://www.hobbyking.com/buddy.asp?code ... DE84C0F0B4
4x45mm Sockethead Screw (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... 7BDB28F318
SF E-Prop 10x4.7 / 254x119.5mm w/ Adapters Black (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 8C311F0718
GWS EP Propeller (RD-1047 254x119mm) (6pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 80E897BE65
Front Wheel Steering Arm & Mount Set 32mm (5sets)
http://www.hobbyking.com/buddy.asp?code ... A68671C4E9
HKSCM12-6 Single Chip Digital Servo (6V) 12g / 1.7kg / 0.16s
http://www.hobbyking.com/buddy.asp?code ... CC3EAF6135
Por javosk
#1128350
realmente los codigos esos funcionan? es que yo veo menos descuento del que dicen y ademas como funcionan? a mi me sale un asterisco al lado del precio pero... eso funciona?
Por GermanGB
#1128433
el asterisco te aparece porque ese precio esta rebajado gracias al codigo o enlace en el que has pinchado, en cuanto a lo que dice la rebaja cada articulo tiene una rebaja independiente. Comprobaras que existe dicha rebaja si abres dos pagina con el mismo articulo y veras que el articulo ocn asterisco es mas barato
Por patalete
#1129138
Abres una nueva pestaña de tu navegador y te registras/logueas en hobbyking, despues haces click sobre los enlaces que hay en este tema y que contiene el codigo o sino lo pegas en la pestaña de tu navegador (ejemplo: http://www.hobbyking.com/buddy.asp?code ... 5FC047600D).
Si el descuento aun esta vigente y el producto se compra en la misma tienda de donde procede el buddy code, europa/hong-kong, te saldra el precio final ya ya con el descuento hecho y con el asterisco al lado. Creo que hay limite de codigos usados por envio asi que escojo los mayores descuentos primero. Si en la barra de direccion borras la parte final (a partir de "&buddycode=....") y la recargas veras el precio original.
Mas descuentos hasta 31 de marzo:
Turnigy Mini Anemometer - Wind Meter (DE Warehouse) Save €: 4.70
Turnigy Watt Meter and power Analyzer (DE Warehouse) Save €: 7.29
Hobby King GT-2 2.4Ghz 2Ch Tx & Rx (DE Warehouse) Save €: 4.42
Turnigy 1700mAh 2S 20C Lipo Pack (Suits 1/16th Monster Beatle, SCT & Buggy) (DE Warehouse) Save €: 0.90
Turnigy 1000mAh 2S 20C Lipo Pack (DE Warehouse) Save €: 1.27
HobbyKing Cutting Mat(DE Warehouse) Save : 0.59
Por Vallekano
#1129856
Round Heli Landing Pad - 7mm (Transparent Blue)
http://www.hobbyking.com/hobbyking/stor ... FC084F290F
Glass Fiber Cloth 450x1000mm 48g/m2 (Ultra Thin)
http://www.hobbyking.com/hobbyking/stor ... ABDEE98339
USB Simulator Cable Phoenix RC
http://www.hobbyking.com/hobbyking/stor ... D98ADC14F6
On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/hobbyking/stor ... 566795DCEE
Por bonet
#1131103
Mas códigos, válidos hasta el 7 de abril.
Imanes para tapas, cabinas, etc.
http://www.hobbyking.com/buddy.asp?code ... 6A4FD68DBD
Cargador, balanceador lipos, sencillo.
http://www.hobbyking.com/buddy.asp?code ... 2610404552
Hélice eléctricos, tipo APC 11x5,5.
http://www.hobbyking.com/buddy.asp?code ... 73A70749B3
Destornillador multiuso.
http://www.hobbyking.com/buddy.asp?code ... 5BB266EC98
Por bonet
#1131341
Deben valer para varios clientes, pues los que he cogido de este hilo siempre me han funcionado.
Pero solo puedo utilizar un máximo de dos referencias con descuento, por pedido.
Muchas gracias, por poner vuestros códigos con descuento, somos tres que volamos y uno que paga.
Por malaga30
#1132007
pongo los mios,no savia que habia esto jejeje,le quedara poco tiempo de validez,pero si sirve hay esta:
Futaba Y Servo Lead 30cm Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... D428A46AAA
Super Light Pivot & Round Hinges D2xW8xL24mm
http://www.hobbyking.com/buddy.asp?code ... CD96CE5C1E
Turnigy Pure-Silicone Wire 14AWG (1mtr - 69A
http://www.hobbyking.com/buddy.asp?code ... 563C192E41
Por Vallekano
#1133785
HobbyKing Multi-Rotor Control Board V2.1 (Atmega168PA)
http://www.hobbyking.com/buddy.asp?code ... 749950D26C
http://www.hobbyking.com/buddy.asp?code ... 2C2ABE1043
HK600GT landing skid (H60039)
http://www.hobbyking.com/buddy.asp?code ... EA71EE401B
HK600GT skid nut (H60064)
http://www.hobbyking.com/buddy.asp?code ... 711BD91EE1
Por coyotefer
#1138839
Por ProKlibe
#1139366
Pongo mis códigos:
TURNIGY Plush 40amp Speed Controller
http://www.hobbyking.com/buddy.asp?code ... 30DDA66353
Turnigy Typhoon 450H 2215H Heli Motor 3550kv
http://www.hobbyking.com/buddy.asp?code ... 765D2D0998
HK450 size Pinion Gear 3.17mm/11T (Align par
http://www.hobbyking.com/buddy.asp?code ... 20C2A30BAF
PolyMax 3.5mm Gold Connectors 10 PAIRS (20PC
http://www.hobbyking.com/buddy.asp?code ... 37217652AC
HK450 size Pinion Gear 3.17mm/13T (Align par
http://www.hobbyking.com/buddy.asp?code ... 01B0AF878C
Por jou
#1140373
Ahí van los mios disponibles hasta el 15 de Mayo.
Turnigy nano-tech 5000mah 4S 25~50C Lipo Pac
http://www.hobbyking.com/buddy.asp?code ... 7E0316670A
NTM Prop Drive 28 Series Accessory Pack
http://www.hobbyking.com/buddy.asp?code ... E17732CFB6
NTM Prop Drive 35 Series Accessory Pack
http://www.hobbyking.com/buddy.asp?code ... 66FA222606
Turnigy Pure-Silicone Wire 10AWG (1mtr) RED
http://www.hobbyking.com/buddy.asp?code ... 739C117C3D
Turnigy Pure-Silicone Wire 10AWG (1mtr) BLAC
http://www.hobbyking.com/buddy.asp?code ... D87A50B0AD
Turnigy 5mm Heat Shrink Tube - RED (1
http://www.hobbyking.com/buddy.asp?code ... C6C96CFB21
4mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?code ... 55A7E1226A
  • 2
  • 3
  • 4
  • 5
  • 13
