Por billy1995
#1186600
Más códigos:
Turnigy Aerodrive SK3 - 50-XX Spare Accessory Pack
http://www.hobbyking.com/buddy.asp?code ... 7DDE0485CC
3.5mm Male/Female Bullet Brushless Motor Extension Lead 100mm
http://www.hobbyking.com/buddy.asp?code ... 987F09AFC9
NTM Prop Drive 35-42 Series 1000KV / 700W (NL Warehouse)
http://www.hobbyking.com/buddy.asp?code ... E80E1A8653
Unos son del día 18 y los otros del día 19.
Espero os sirvan.
Por Lanius
#1189011
Extra Codes, You can save -19.08% for all of this products with:http://rc-buddy.com/user/Lanius! Codes from RC-Buddy.com
Male Molex 1.25 to Female JR Servo Extension (1pc)
Savings: 36.36 % / $0.2
Price after: $0.35
Weight: 6 g
Extra Codes, You can save 39.31% for all of this products with:http://rc-buddy.com/user/Lanius! Codes from RC-Buddy.com
Servo Terminals (JR) Gold Plated (10pairs/set)
Savings: 31.84 % / $0.57
Price after: $1.22
Weight: g
Control Rod/ABS Sleeve (1pc/bag)
Savings: 24.11 % / $0.27
Price after: $0.85
Weight: 21 g
Hex locknuts M2.5 10pc
Savings: 63.29 % / $0.5
Price after: $0.29
Weight: 20 g
L-C Power Filter for FPV A/V Systems
Savings: 43.14 % / $1.29
Price after: $1.70
Weight: 19 g
LED Corn Light 12V 1.8W (9 LED) - Green (2pcs)
Savings: 24.06 % / $0.64
Price after: $2.02
Weight: 14 g
LED Corn Light 12V 1.8W (9 LED) - Red (2pcs)
Price after: $2.02
Weight: 14 g
Rounded Phillips Head M2x12 (10pcs/set)
Savings: -44.29 % / $-0.62
Price after: $2.02
Weight: 11 g
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
Savings: 83.33 % / $0.3
Price after: $0.06
Weight: g
Turnigy 5mm Heat Shrink Tube - <b>RED</b> (1mtr)
Savings: -842.86 % / $-2.95
Price after: $3.30
Weight: g
Turnigy 2mm Heat Shrink Tube - BLACK (1mtr)
Savings: 88 % / $0.22
Price after: $0.03
Weight: g
#1189650
unos cuantos codigos
ZIPPY Compact 2200mAh 3S 25C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... C5A976F924
Turnigy Battery Strap 330mm
http://www.hobbyking.com/buddy.asp?code ... 3A5BE64315
Light weight horn set
http://www.hobbyking.com/buddy.asp?code ... DEE7346B60
Super Light Pivot & Round Hinges D2xW8xL28mm (12pcs)
http://www.hobbyking.com/buddy.asp?code ... 9ED5348078
Por tazoom
#1189856
Extra Codes, You can save 49.14% for all of this products ! Codes from RC-Buddy.com
[img]http://rc-buddy.com/BuddyPrice/Image/HLFT-01
[/img]
Polyester Velcro Peel-n-stick adhesive side V-STRONG (1mtr)
Savings: -75.31 % / $-1.8
Price after: $4.19
Weight: g
Extra Codes, You can save -80.6% for all of this products ! Codes from RC-Buddy.com
[img]http://rc-buddy.com/BuddyPrice/Image/OR005-00601
[/img]
Silicon fuel pipe (1 mtr) White for Nitro Engines 4x2.5mm
Savings: -274.11 % / $-3.07
Price after: $4.19
Weight: 30 g
[img]http://rc-buddy.com/BuddyPrice/Image/OR013-00701
[/img]
Parts Boxes (PP Transparent) (1pc/bag)
Savings: 13.27 % / $0.13
Price after: $0.85
Weight: 28 g
[img]http://rc-buddy.com/BuddyPrice/Image/HE-28-1
[/img]
HobbyKing 4-6min Epoxy Glue
Savings: -6.74 % / $-0.06
Price after: $0.95
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/WH-5MM-BLACK
[/img]
Price after: $0.06
Weight: g
Extra Codes, You can save 1.16% for all of this products ! Codes from RC-Buddy.com
[img]http://rc-buddy.com/BuddyPrice/Image/WH-2MM-BLACK
[/img]
Price after: $0.03
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/TR-WP-WH
[/img]
High Density Waterproof LED Flexible Strip - White (1mtr)
Savings: 35.93 % / $1.57
Price after: $2.80
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/WH-3MM-BLACK
[/img]
Turnigy 3mm Heat Shrink Tube - BLACK (1mtr)
Savings: 88.57 % / $0.31
Price after: $0.04
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/AM2001-60x10
[/img]
60CM Servo Lead Extention (Futaba) 26AWG (10pcs/set)
Savings: 98.85 % / $3.45
Price after: $0.04
Weight: 93 g
[img]http://rc-buddy.com/BuddyPrice/Image/OR005-00106
[/img]
Fuel Tank 550cc
Savings: 97.74 % / $1.73
Price after: $0.04
Weight: 95 g
[img]http://rc-buddy.com/BuddyPrice/Image/T1500.3S.25C
[/img]
Turnigy 1500mAh 3S 25C Lipo Pack
Savings: 13.23 % / $1.6
Price after: $10.49
Weight: 142 g
[img]http://rc-buddy.com/BuddyPrice/Image/AM2001-20x10
[/img]
20CM Servo Lead (Futaba) 32AWG Ultra Light (10pcs/set)
Savings: -455.03 % / $-8.6
Price after: $10.49
Weight: 27 g
[img]http://rc-buddy.com/BuddyPrice/Image/HX5010
[/img]
HXT 6.9kg / 39.2g / .16sec Twin bearing servo
Savings: 8.71 % / $0.4
Price after: $4.19
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/Magnet-R
[/img]
Strong Rare-Earth Button Magnets (10pcs/set)
Savings: 77.67 % / $1.67
Price after: $0.48
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/OR016-502x10
[/img]
Linkage Stopper M3x2xL11.2mm (10pcs/set)
Savings: 36.18 % / $0.55
Price after: $0.97
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/12-00503x10
[/img]
Nylon Clevis 2x29mm (10pcs)
Savings: 25 % / $0.16
Price after: $0.48
Weight: g
[img]http://rc-buddy.com/BuddyPrice/Image/MA1160
[/img]
Master Airscrew propeller 11x6
Savings: 34.36 % / $0.89
Price after: $1.70
Weight: 33 g
[img]http://rc-buddy.com/BuddyPrice/Image/TW001-00701
[/img]
Turnigy Mini Anemometer (Wind Meter)
Savings: 76.71 % / $13.77
Price after: $4.18
Weight: g
#1190017
Otros más:
Servo Mount/Protectors White (1set/bag) 64mm x 67mm
http://www.hobbyking.com/buddy.asp?code ... 2AF16397CB
Servo Mount/Protectors (2pcs/bag) 50mm
http://www.hobbyking.com/buddy.asp?code ... CEB91782D7
Tail Wheel System. w/ Steering & Spring 40-90 Size
http://www.hobbyking.com/buddy.asp?code ... 52BBA5BB3A
http://www.hobbyking.com/buddy.asp?code ... 9B2B7714AF
Por pedritom
#1190271
Ahí van otros cuantos:
Sprung Steering Tailwheel Assembly 0.40~0.60 Size
Savings: 8.27 % / $0.33
Price after: $3.66
Weight: 49 g
XT60 Harness for 2 Packs in Series (1pc)
Savings: 12.06 % / $0.24
Price after: $1.75
Weight: g
JST Series Connector
Savings: -96.63 % / $-0.86
Price after: $1.75
Weight: 15 g
Nylon Spinner with Alloy Backplate 57mm White
Savings: 66.6 % / $3.49
Price after: $1.75
Weight: 45 g
Price after: $4.19
Weight: g
Twisted 15CM Servo Lead Extention (Futaba) 22AWG (5pcs/set)
Savings: -110.55 % / $-2.2
Price after: $4.19
Weight: 31 g
Por bonet
#1190387
Unos códigos mas, válidos hasta 26/1/2013.
http://www.hobbyking.com/buddy.asp?code ... 584FA9EEFF
4 x AA Battery Holder (Rx Pack)
http://www.hobbyking.com/buddy.asp?code ... AF4CEB7BB5
JM 6x4 /152.5x102mm propeller (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... B11494539E
Turnigy AA LSD 2400mAh Low Self Discharge (ready to use)
http://www.hobbyking.com/buddy.asp?code ... FE7AFF8F04
Por Jaume
#1191185
Quedan unos 12 dias para estos códigos. Tornillería, pegamentos y algunos conos.
Grub Screw set M3x3 10 Pack
http://www.hobbyking.com/buddy.asp?code ... 9B80EF4099
4x40mm Countersunk Screw with shank (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... 9AD21AE884
3x35mm Countersunk Screw with shank (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... 723F856B60
4x40mm Sockethead Screw (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... 2BCA41C164
5x20mm Sockethead Screw (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... B1ACC2B627
http://www.hobbyking.com/buddy.asp?code ... 085320A28E
Nylon Blind Nut M6 (4Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code ... 42F55FB173
Hex Screw M3x10 (20pcs)
http://www.hobbyking.com/buddy.asp?code ... B3A39ED967
Hex Screw M2x8 (20pcs)
http://www.hobbyking.com/buddy.asp?code ... BE5397F691
http://www.hobbyking.com/buddy.asp?code ... 6226389418
Landing Gear Wheel Stop Set Collar 6x2.1mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... D81F2CCB99
Landing Gear Wheel Stop Set Collar 8x3.1mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... B7A42BB9B1
Grub Screw Set M3x4 10 Pack
http://www.hobbyking.com/buddy.asp?code ... 218286E400
5x35mm Sockethead Screw (10pcs/pack)
http://www.hobbyking.com/buddy.asp?code ... 06D1973749
Spring Washers #6 (bag of 100pc)
http://www.hobbyking.com/buddy.asp?code ... 0573839338
Socket Head Bolt 4x30mm (10 pack)
http://www.hobbyking.com/buddy.asp?code ... 5F3A973AD5
Self-Tapping Screws 2x8 (bag of 100pc)
http://www.hobbyking.com/buddy.asp?code ... 15C77BE801
Washers #3(bag of 100pc)
http://www.hobbyking.com/buddy.asp?code ... A1DE636C22
Washers #2(bag of 100pc)
http://www.hobbyking.com/buddy.asp?code ... 44DC77F385
Landing Gear Wheel Stop Set Collar 6x5.1mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 7428AF6FA6
Hex-nuts M6 10pc
http://www.hobbyking.com/buddy.asp?code ... E04D535F93
Insta-Set CA Accelerator 2. oz
http://www.hobbyking.com/buddy.asp?code ... 5FB2ADAF5B
HobbyKing Super Glue CA (50g / 1.7oz) Medium
http://www.hobbyking.com/buddy.asp?code ... 26D22EF8D7
HobbyKing Super Glue CA (50g / 1.7oz) Super Thin
http://www.hobbyking.com/buddy.asp?code ... 7B5F8255B1
TL-262 Thread Locker & Sealant High Strength
http://www.hobbyking.com/buddy.asp?code ... E36A0334E8
Un-Cure CA Debonder 1. oz
http://www.hobbyking.com/buddy.asp?code ... AFA399B3AD
Slow-Cure 30 Min Epoxy 4.5 oz
http://www.hobbyking.com/buddy.asp?code ... 6146FB2311
soft push rod (Snakes) - D3 x 1150mm (4pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 68E700B8D1
Push Rod Sleeves (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... 1DA1D9C9E0
3 Inch Carbon Fiber Spinner suits 6 and 8mm shafts
http://www.hobbyking.com/buddy.asp?code ... 15E3C779C8
Nylon Spinner with Alloy Backplate 63mm Red
http://www.hobbyking.com/buddy.asp?code ... A27D2486CA
Hobby Mini Saw Set
http://www.hobbyking.com/buddy.asp?code ... 26ABB424F6
Nylon Spinner with Alloy Backplate 75mm Red
http://www.hobbyking.com/buddy.asp?code ... 1E047D167B
Por octavianmp
#1192294
Find my codes here: http://hk.rc-international.info/swarm/octavianmp (valid until February 03, 2013)
8045 SF Props 2pc Standard Rotation/2 pc RH Rotation (Black) Save US$: 1.55
2213N 800Kv Brushless Motor Save US$: 0.96
8045 SF Props 2pc Standard Rotation/2 pc RH Rotation (Red) Save US$: 1.56
Propeller Adapter (Colet Type) 3MM Save US$: 0.44
Browse buddycodes on RC International now with your Android mobile phone or tablet with RC International unoffcial Hobbyking app
Por juerwotow
#1195981
Hola si queréis pillar el Sirius, un avión FPV que recomiendan mucha gente!!!
http://www.hobbyking.com/buddy.asp?code ... D77F296A5D
Y el motor para dicho avión:
http://www.hobbyking.com/buddy.asp?code ... 02840FD658
Y si queréis ponerle luces al avión simplemente conectándolo al receptor:
http://www.hobbyking.com/buddy.asp?code ... 33841D0D70
Un saludo!! y GRACIAS!!
Por tazoom
#1198457
Extra Codes, You can save 30.4% for all of this products ! Codes from RC-Buddy.com
3K Woven Carbon Fiber Cloth (160g/m2) 1mtr
Savings: 12.86 % / $3.09
Price after: $20.94
Weight: g
Turnigy nano-tech 2200mah 3S 25~50C Lipo Pack
Savings: 38.19 % / $6.87
Price after: $11.12
Weight: g
Turnigy High Density R/C LED Flexible Strip-White (1mtr)
Savings: 55.32 % / $2.91
Price after: $2.35
Weight: g
Turnigy High Density R/C LED Flexible Strip-Red (1mtr)
Savings: 41.69 % / $1.68
Price after: $2.35
Weight: g
Turnigy High Density R/C LED Flexible Strip-Green (1mtr)
Savings: 36.23 % / $1.46
Price after: $2.57
Weight: g
3x20mm Countersunk Screw (10pcs/pack)
Savings: 93.68 % / $0.89
Price after: $0.06
Weight: 20 g
Hex locknuts M3 10pc
Savings: 56.96 % / $0.45
Price after: $0.34
Weight: 20 g
Extra Codes, You can save 23.18% for all of this products ! Codes from RC-Buddy.com
Turnigy 1.5mm Hex Screwdriver
Savings: 28.68 % / $0.37
Price after: $0.92
Weight: 29 g
Turnigy Heat Shrink Tube 100mm BLACK (1mtr)
Savings: 13.09 % / $0.36
Price after: $2.39
Weight: 233 g
Alloy Anti-Slip TX Control Sticks Short (M3 for Futaba - Blue)
Savings: -26.46 % / $-0.5
Price after: $2.39
Weight: 25 g
2.5x10mm Sockethead Screw (10pcs/pack)
Savings: 75.88 % / $1.51
Price after: $0.48
Weight: 15 g
Turnigy AAA LSD 900mah Low Self Discharge (ready to use)
Savings: 30.3 % / $0.3
Price after: $0.69
Weight: 19 g
Alloy Folding Spinner 30mm / 3.2mm shaft
Savings: 24.01 % / $0.73
Price after: $2.31
Weight: 29 g
Por tazoom
#1198459
Extra Codes, You can save -10.19% for all of this products ! Codes from RC-Buddy.com
USB Simulator Cable XTR/AeroFly/FMS
Savings: 12.93 % / $0.67
Price after: $4.51
Weight: g
Folding Prop Spinner 40mm / 5.0mm shaft
Savings: 12.85 % / $0.68
Price after: $4.61
Weight: 45 g
Team Turnigy Prop Protectors (X Large - 1pr)
Savings: -131.66 % / $-2.62
Price after: $4.61
Weight: 41 g
Por tazoom
#1200128
No se porque a veces no salen las fotos de los articulos... en fin, ahi quedan para el que los necesite.
Extra Codes, You can save -45.53% for all of this products ! Codes from RC-Buddy.com
[img]http://rc-buddy.com/BuddyPrice/Image/017000023
[/img]
Alloy Fuel Dot for large scale Gas Planes
Savings: -127.13 % / $-6.28
Price after: $11.22
Weight: 29 g
[img]http://rc-buddy.com/BuddyPrice/Image/S527
[/img]
Twelve 2-56 Gold-N-Clevises
Savings: -111.3 % / $-5.91
Price after: $11.22
Weight: 50 g
Por san
#1202930
Aqui os dejo unos codigo de descuento para los respuestos de los helis FBL100 turnigy, frisky y WL V922.
Turnigy FBL100 Landing Skids
http://www.hobbyking.com/buddy.asp?code ... 8EE3178168
Turnigy FBL100 Swashplate
http://www.hobbyking.com/buddy.asp?code ... BC99306249
Turnigy FBL100 Tail Rotor Blade (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... E742DAFB1A
Turnigy FBL100 Main Blades
http://www.hobbyking.com/buddy.asp?code ... 2DFCCF8936
Turnigy FBL100 Tail Motor
http://www.hobbyking.com/buddy.asp?code ... D745C787A2
Turnigy FBL100 Main Blade Grips (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... C07D75F25D
Turnigy FBL100 Vertical Tail Fin
http://www.hobbyking.com/buddy.asp?code ... 1EFCD7EA4E
Turnigy FBL100 Tail Boom (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 6440B09B38
Turnigy FBL100 Main Gear (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... B127B8BA28
Un saludete :mrgreen:
Por san
#1203284
Mas codigos :lol: :lol: :lol: :lol:
Rhino 360mAh 2S 7.4v 20C Lipoly Pack
http://www.hobbyking.com/buddy.asp?code ... 8CA88C5838
Hobby King 4.3g / .5kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?code ... 79D3503496
Carbon Fiber Rod (solid) 1x750mm
http://www.hobbyking.com/buddy.asp?code ... 07DF7DD469
Carbon Fiber Rod (solid) 1.5x750mm
http://www.hobbyking.com/buddy.asp?code ... 8BF019E755
Carbon Fiber Square Tube 750x3mm
http://www.hobbyking.com/buddy.asp?code ... DA0DFD1D38
Carbon Strip 1x3x750mm (5pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 2F1788C41C
8x4 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code ... C956361AFB
APC Style Propeller 8x4 (2 pc)
http://www.hobbyking.com/buddy.asp?code ... 3ABEA644AF
Pivot & Round Hinges 2.5x48 (10pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 640FEDF2D7
Espero que sirvan.
  • 5
  • 6
  • 7
  • 8
  • 9
  • 13
