Por tonete
#1260914
Por juerwotow
#1261185
Por Biela
#1262839
#1266503
Algunos codigos
ZIPPY Compact 2200mAh 3S 35C Lipo Pack (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 8835E50976
Turnigy 7 in 1 Mega Meter Battery Checker/Watt Meter/Servo Tester (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... DC4014C739
TURNIGY Plush 10amp 9gram Speed Controller (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... ADE3C12EE2
Turnigy nano-tech 2200mah 3S 45~90C Lipo Pack (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... CB080B0385
Nylon XT60 Connectors Male/Female (5 pairs) GENUINE (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... CA51C2D629
Nylon T-Connectors Female (10pcs/Bag) (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 084179E382
ZIPPY Compact 1300mAh 3S 25C Lipo Pack (UK Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 3D7A5801F2
APC Style Propeller 5x5 (2 pc) ( UK Warehouse )
http://www.hobbyking.com/buddy.asp?code ... 31738E640C
k los disfruten
Por bonet
#1266690
Unos códigos HK almacén internacional, con descuento, válidos hasta 24/3/2014.
Hélice, 4 x 3 E Turnigy Speed Propeller (2pc)
http://www.hobbyking.com/buddy.asp?code ... B75C4DF5A9
Servo, Turnigy 620DMG+HS High Torque Digital Servo (MG) 10.6kg / .13sec / 52g
http://www.hobbyking.com/buddy.asp?code ... 52E751DE79
Lipo, Turnigy nano-tech 1300mAh 3S 45~90C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... DAA1C53CB6
Hélice, JM 6x4 /152.5x102mm propeller (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... DE013BDF94
#1266800
una palas para heli tamaño 500
500 Size Fiberglass helicopter blades 430mm (EU warehouse)
http://www.hobbyking.com/buddy.asp?code ... D7A088F992
Por san
#1267286
De carbono va la cosa :lol: :lol: Espero que os sirvan. :wink:
Un saludete. :mrgreen:
Carbon Fiber Square Tube 750x3mm
http://www.hobbyking.com/buddy.asp?code ... 127A7A7F92
Carbon Fiber Rod (solid) 1.5x750mm
http://www.hobbyking.com/buddy.asp?code ... A3D1C8C1FC
Carbon Strip 0.5x3x750mm (5pcs/set)
http://www.hobbyking.com/buddy.asp?code ... 5DFC4C4B6E
Carbon Fiber Rod (solid) 1.8x750mm
http://www.hobbyking.com/buddy.asp?code ... 7BD4883F52
Carbon Fiber Rod (solid) 1x750mm
http://www.hobbyking.com/buddy.asp?code ... 70ADA4C0AB
#1267725
Eje principal 450 dfc
http://www.hobbyking.com/buddy.asp?code ... 471ABD4CD4
eje principal 500 dfc
http://www.hobbyking.com/buddy.asp?code ... 361ABA40C3
servos para cíclico helicóptero tamaño 500 piñonearía metálica muy buenos los llevo en mi Aling t rex 500 DFC
http://www.hobbyking.com/buddy.asp?code ... 097BE07C19
#1268014
Massssssssss,,, :lol: :lol:
H.K EUROPA
ZIPPY Flightmax 2200mAh 3S1P 40C (EU warehouse)
http://www.hobbyking.com/buddy.asp?code ... F0A7E8A8D2
Turnigy R/C Helicopter Blade Balancer (Metal) (EU warehouse)
http://www.hobbyking.com/buddy.asp?code ... 34E14DFCB5
Transmitter Neck Strap Balancer (Futaba) (EU warehouse)
http://www.hobbyking.com/buddy.asp?code ... 0F2C9E3A45
Nylon XT90 Connectors Male (5pcs/bag) (EU warehouse)
http://www.hobbyking.com/buddy.asp?code ... 5B1363AE1F
Wire Mesh Guard Red 3mm (1mtr) (EU Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 34FFA4BC8E
Wire Mesh Guard Blue 6mm (1mtr) (EU Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 6FA72E7A5A
Red Anodised Aluminum M3 Countersunk Washer (8pcs) (EU Warehouse)
http://www.hobbyking.com/buddy.asp?code ... 7C0F46FB2B
#1269259
Turnigy High-End Fiberglass Canopy for Trex 500
http://www.hobbyking.com/buddy.asp?code ... 02FE53622C
Replacement Fuel Tube - Trooper Nitro (2pc)
http://www.hobbyking.com/buddy.asp?code ... 10A2CD0647
HK-450 PRO Flybarless DFC Main Shaft
Turnigy MG930 Digital Metal Gear Servo 3.6kg / 26g / 0.14sec
Por misama
#1270957
Receptor 2,4 Ghz 8 canales OrangeRx Futaba FASST Compatible
http://www.hobbyking.com/hobbyking/stor ... ff=1011314
Hobbyking Parallel charging Board for 6 packs 2~6S (XT-60)
FrSky TFR6 7ch 2.4Ghz Receiver FASST Compatible
Hobbyking 2-8S Cell Checker with Low Voltage Alarm
Turnigy Long Shaft 4pc Hex driver set
Model Pilot (H92 x W88 x D44mm)
algunos mas
Male JST-XH <-> Female Kokam 2S 10cm (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 377A0931A8
Battery Velcro Strap (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 3040BDC17F
Scorpion Lipoly Lock Strap 205mm (Small) x 3
http://www.hobbyking.com/buddy.asp?code ... 9FDCF1529B
Turnigy AA LSD 2400mAh Low Self Discharge (ready to use)
http://www.hobbyking.com/buddy.asp?code ... C051455CE8
325mm Fiber Glass Main Blades
http://www.hobbyking.com/buddy.asp?code ... 2B7EEEC20C
Por francan
#1275407
un saludo a los foreros
hay va mi primer mensaje
estos codigos son validos hasta 17 de mayo 2014
precio ahorro
Hobby rey ​​60A UBEC 4A (almacén de la UE) $ 17.43 $ 2,72
http://www.hobbyking.com/buddy.asp?code ... 54E5322FE9
Serie NTM Prop Drive 35-30A 1400KV / 560w (Almacén de la UE) $ 16.92 $ 1,11
http://www.hobbyking.com/buddy.asp?code ... F62B4FC65E
Turnigy 2200mAh 3S 30C Lipo Pack (almacén de la UE) $ 12,94 $ 1.91
http://www.hobbyking.com/buddy.asp?code ... C5E4041BC8
TGS Sport 9x6E Precision hélice (Almacén de la UE) $ 2,12 $ 0,23
http://www.hobbyking.com/buddy.asp?code ... 805737BEED
APC Style Propeller 10x5 (2 pc) (almacén de la UE) $ 2,02 $ 0.47
http://www.hobbyking.com/buddy.asp?code ... 43172C9B90
Style Hélice 11x5.5 (2 pc) (almacén de la UE) $ 2,70 $ 0,29
http://www.hobbyking.com/buddy.asp?code ... C20810B42C
NTM 35 Motor Mount Spacer / Stand Off 10 mm (4 piezas) $ 0,92 $ 0,03
http://www.hobbyking.com/buddy.asp?code ... 61F6E82B35
45mic Wing Tape x 45 mm x 100 m (ancho - Rojo) (Almacén de la UE) $ 1,42 $ 0,37
http://www.hobbyking.com/buddy.asp?code ... 47714AA79C
45mic Wing Tape x 45 mm x 100 m (ancho - Amarillo) (Almacén de la UE) $ 1,42 $ 0,37
http://www.hobbyking.com/buddy.asp?code ... E41D96E4AE
Pom Horns 20x27mm (10pcs/set) (almacén de la UE) $ 1,02 $ 0,16
Por GermanGB
#1276032
Aqui van unos cuentos más, perfectos para un Bixler o cualquier otro:
-HXT900 9g / 1.6kg / .12sec Micro Servo
Code:http://www.hobbyking.com/buddy.asp?code ... CB70EE0517
-APC Style Propeller 7x5 (2 pc)
Code:http://www.hobbyking.com/buddy.asp?code ... 02C1D27934
-Hobbyking Bixler and Bixler 2 Motor Mount Upgrade
Code:http://www.hobbyking.com/buddy.asp?code ... A54028788C
Por juerwotow
#1277220
  • 9
  • 10
  • 11
  • 12
  • 13
