Por Pichi_Arg
#1359318
KAREL NOVAK escribió:Grande Pichi !!!!!! ya está en el aire de nuevo. Me alegro, ojalá algún día lo pueda ver en persona.
Abrazo y que sigan esos buenos vuelos.
Cuando quieras amigazo!!!
Por ahora, sigue en el aire ;) ...aprovechá y venite para este lado :mrgreen:
Por gully
#1379816
Hola Pichi_Arg
And a happy new year to you my friend.
It has been quite a while, so I thought I would drop by to see how your Pucara is holding up.
Is the larger version still on the drawing board.
regards,
Gully
Por Pichi_Arg
#1379838
gully escribió:
Vie, 05 Ene 2018 7:25
Hola Pichi_Arg
regards,
Gully
Hi Gully!!!
Have a Happy New Year too!!!
I´m in the same Ia-58 scale project, but with more details.
I want to make a "short kit" version so that all lovers of Pucará can enjoy this beautiful plane.
You can follow the progress of that construction here:
https://www.rcgroups.com/forums/member.php?u=343020
Have you flown your Pucará ???
Best regards friend!!
Por gully
#1379870
oooh! very nice :D (Just had a quick look)
Will follow along over there.
My Pucara will have to wait until I retire now. :(
Work and life in general are just not leaving me with any free time or spare cash.
I have not flown any of my other models in a couple of years now either.
(If you lived in Australia I would give it to you to finish!) :D
Chat soon over on your new build
Regards,
Gully
Por Pichi_Arg
#1379886
gully escribió:
Vie, 05 Ene 2018 21:52
Regards,
Gully
Thanks dude!
I would have been happy to finish your model, but more to be able to learn working by your side.
I'll keep you updated on the project!
A big hug!
Por Pichi_Arg
#1413939
Hola compañeros!
Lamento que haya pasado tanto tiempo, pero finalmente tengo acabado este proyecto para todo aquel que le interese tener un Pucara en su hangar.
Para aquellos que estan en America, lo podran conseguir en Manzano Laser Works:
https://manzanolaser.com/FMA-IA-58-Pucara_p_3438.html
Para los de Europa:
arcatcnc@gmail.com
Por cualquier duda, pueden consultarme a ese email.
Saludos!!!!
Por pa22
#1413963
Sergio, en hora buena por el término del proyecto, aún más estando Manzano contigo :shock:
En lo personal te agradézco mucho el que lo hayas hecho, como te comenté en su momento para mí el Pucara es un avión simbólico y emblemático, al rededor de él forjé grandes amigos y compañeros caídos. De los tres COIN que puder volar en activo siempre agradeceré a la Fuerza Aerea Argentina por darnos la posibilidad de probar ese gran avión. Bronco OV-10 y AT27 Tucano, grandes aviones ..... IA-58 Pucara es otro nivel, por arriba de él solo el A-10.
EL Pucara no terminó, evoluciónó y el 16/11/2020 voló el IA-58 Fénix como un COIN-RECON de gran capacidad de combate sumada a una aviónica y tecnología RECON de punta.
Mi eterno agradecimiento al 2do. Escuadrón de Exploración y Ataque de la 3era. Brigada de la Fuerza Aerea Argentina. El ToTo Juan y Córdoba por siempre. :wink:
Por aubonel
#1431904
Buenas, quiero hacerles una consulta con respecto al Pucara y su tren de aterrizaje...
Segun los libros, si lo queremos llevar a como se ven en la realidad el tren quedaria muy atras del CG del modelo lo que haría que no despegue del suelo. Sin embargo vi varios modelos de este avion donde se ve que el tren esta atras (como es en la realidad). La consulta es si esto lo compensan con algo o los libros explican algo teorico que no pasa en la realidad?
Por pa22
#1431905
aubonel escribió:
Lun, 13 Oct 2025 2:00
No sé si estás diseñando uno, del Pucará han habido varias versiones en modelismo ..... debes considerar que un avión como el Pucará en maqueta hacerlo a 100% fiel al real es casi imposible.
Que modelos y donde has visto el Pucará como maqueta R/C ? :? LIbros, cuales ? ...... si un tren principal queda muy atrás del cg normalmente se varía la incidencia del ala, horizontal o ambos y la geometría del ala del Pucará no da para estar jugando mucho con la incidencia, obviamente también dependerá el perfil.
Esperemos por Sergio aparezca que diseñó completamente el suyo y lo aclare porque también depende la escala el de él un poco más pequeño de 1:6 y no fue fácil, yo construí hace años el Pucará de 1,40m para 2 x .15 o eléctrico y tenía el tren principal como el original pero tenía de incidencia en el ala casi 4 grados y el horizontal -2 grados ..... el de Sergio por el tamaño es muchísimo más estable y está mucho mejor diseñado, el de 1,40M es divertido pero es un limón y para nada fácil construirlo, otra cosa es el 1:1 pero ese es solo para los "elegidos" 8)
Suerte !!!
  • 8
  • 9
  • 10
  • 11
  • 12
