- Lun, 19 Ene 2009 17:09
#779904
Que os parece este servo para el paso de un Raptor 50
FEATURES: Digitally enhanced microprocessors cut about 1/2 the response time
from transmitter input to servo reaction.
Coreless motor
Dual ball bearings on the output shaft
Plastic/nylon gear train
Moderately high speed
High current, high capacity wire lead with low resistance
Case is made of black plastic
Dust and water resistant (Not waterproof)
Works well with all control surfaces on F3C helicopters or precision
fixed wing aircraft.
One year warranty
INCLUDES: One Digital All Purpose Servo w/Small Round Horn
Four Rectangular Grommets
Four Brass Bushings
Four Mounting Screws
One Large Round Horn
One Six Arm Horn
SPECS: Speed: .14 sec/60 degrees (based on 4.8V rating)
Torque: 92 oz-in (6.6 kg-cm) (based on 4.8V rating)
Weight: 1.8 oz (50g)
Power Supply: 4.8V (Futaba does not recommend using 6V)
Length: 1.6" (41mm)
Width: .8" (20mm)
_ Height: 1.5" (38mm)
Coreless motor
One year warranty
Four Brass Bushings
One Six Arm Horn
Length: 1.6" (41mm)
Width: .8" (20mm)
Hirobo Freya 12S, Fuselage NOVA 4 - Cabeza SSL Hirobo
Hirobo Freya 12S, Cabeza SSZ
http://www.aeromodelismoourense.com
http://www.helicopteros-rc.com
