- Mié, 09 May 2007 21:37
#466194
Buenas
Saturndj aquí los tienes he puesto todos:
REFERENCIA DESCRIPCION PVP EN €
999-300 Kit, N9, completo 950,00
100-208 M2X8 Socket Head Cap Bolt 1,30
100-210 M2X10 Socket Head Cap Bolt 1,70
100-212 M2X12 Socket Head Cap Bolt 1,70
100-251 M2 Regular Nut 1,30
100-254 M2 Flat Washer Normal 0,85
100-306 M3X6 Socket Head Cap Bolt 1,70
100-308 M3X8 Socket Head Cap Bolt 1,70
100-310 M3X10 Socket Head Cap Bolt 1,70
100-312 M3X12 Socket Head Cap Bolt 1,70
100-316 M3X16 Socket Head Cap Bolt 1,70
100-320 M3X20 Socket Head Cap Bolt 2,15
100-335 M3x35 Socket Head Cap Bolt 2,55
100-340 M3X40 Socket Head Cap Bolt 1,70
100-351 M3 Nylock nut 1,30
100-354 M3 Flat washer normal 1,70
100-364 M3x4 Set Screw 1,70
100-406 M4x6 Socket Head Bolt 3,85
100-408 M4X8 Socket Head Cap Bolt 3,40
100-440 M4X40 Socket Head Cap Bolt 3,40
100-440A M4X40 Socket Head Cap Bolt, Special 4,25
100-451 M4 Nylock nut 2,15
100-464 M4X4 Set Screw 2,15
100-466 M4X6 Set Screw 2,15
100-472 M4X20 Set Screw 2,55
100-516 M5X16 Socket Head Bolt 3,00
100-550A M5X50 Socket Head Cap Bolt 3,40
100-551 M5 NyLock Nut 1,30
100-554 M5 flat washer 1,30
101-306 M3X6 Button Head Bolt 3,40
101-308 M3X8 Button Head Bolt 3,40
101-310 M3X10 Button Head Bolt 3,40
101-408 M4X8 Button Head Bolt 4,25
101-412 M4X12 Button Head Bolt 4,25
101-420 M4X20 Button Head Bolt 4,25
101-430 M4x30 Button Head Bolt 4,25
106-115 Servo Hold Down 4,25
106-120 Main Shaft Shim 1,50
106-301 3mm Bolt Shim 1,70
106-305 Engine 0.5mm Shim 2,15
106-310 Engine mount shim, 1.0mm 2,15
106-315 Engine 1.5mm Shim 2,15
106-326 5.5x26 threaded Hex Stand off 1,70
106-401 4mm Bolt Shim 0,85
106-601 6mm Tail Shim 1,50
106-801 Head Shim 0.5mm 2,15
106-802 Head Shim 0.75mm 2,15
106-803 Washer, 8x1.0mm 1,70
106-806 Head O-rings Neoprene HR:70~80 6,80
106-807 Fuel Tank Edge Grommet 7,65
106-808 TT O-ring 3,40
106-810 Fuel Tank Stopper Grommet 3,40
106-813 Tail Pitch Slider Lock Ring 0,85
106-900 Jesus Pin 3,40
106-910 Tail Drive Shaft Roll Pin 2,15
106-920 2mm pin clips 1,30
106-921 Tail Pitch Link Pin 1,30
106-922 2mm washout pins 1,70
106-923 2.4mm Tail Gear Pin 1,70
106-925 Pin, 2.5x32, anti-rotation 2,55
106-930 M3 Step Washer 3,40
106-952 Governor Sensor Mount, molded 4,25
106-955 Hex Starter Adaptor 7,45
106-965 Tail push rod sleeve 1,30
107-012 Link rod, 2.5x12mm 2,15
107-024 Link rod, 2.5x24mm 2,55
107-035 Link rod, 2.5X35mm 3,00
107-065 Link rod, 2.5x65mm 3,40
107-075 Link rod, 2.5x75mm 3,40
107-100 Ball Link 2.5mm 3,00
107-101 Ball Link 2.5mm, short 0,85
107-103 2mm Pivot Ball (Shorter for Tail Rotor) 0,85
107-104 2mm Pivot Ball 3,40
107-106 3x4.5mm Pivot Ball 3,40
107-108 3x7mm Pivot Ball 3,40
107-155 Link rod, 2.5x155mm 3,40
107-295 2.5x295mm Tail Control Rod 1,70
108-105 10x19x5 Clutch Bearing 10,20
108-124 Bearing, 12x18x4 6,40
108-125 12x21x5 Main Shaft Bearing 10,85
108-151 15x23x11 Sprag/one way bearing 76,50
108-155 15x24x5 Main gear Hub Bearing 12,75
108-373 3x7x3 Bell Crank Bearing 5,10
108-383 3x8x3 Bell Crank Bearing 5,10
108-470 4x7x2.5 Flanged Servo Pivot Bearing 6,80
108-472 4x7x2.5 Bell Crank Bearing 6,40
108-483 Bearing, 4x8x3 6,40
108-484 Bearing, 4x8x4 flanged 6,40
108-510 5x10x4 Tail Grip Bearing 5,95
108-511 5x10x4 Tail Thrust Bearing 6,40
108-615 Bearing , 6x15x5 6,40
108-812 8x12x2.5 Open Tail Slider Bearing 6,40
108-814 8x14x4 Clutch Bell Bearing 6,40
108-816 8X16X5 Main Grip Bearing 15,30
108-817 8X16X5 Main Grip Thrust Bearing 10,65
109-351 3x5x1.6mm Spacer 1,30
109-352 3x5x2mm Spacer 1,30
109-354 Spacer, 3x5x4 1,70
109-355 3x5x5mm Spacer 1,70
109-462 4x6x2mm Spacer 1,30
109-463 4x6x3mm Spacer 1,30
109-614 Output Shaft Sleeve 1,70
110-115 15T Pinion Gear 27,65
110-124 124T Main Gear 42,50
110-138 Main Shaft Collar 6,80
110-140 Main Shaft 13,60
110-142 Main Shaft Bearing Block Plastic 2,55
110-145 70T Crown Gear 34,00
110-146 Crown Gear Hub 23,40
110-150 Main Gear Hub Collar 3,40
110-152 Sprag Bearing Inner Race 21,25
110-153 Sprag Bearing Outer Race 8,10
110-155 Clutch Bearing Block Plastic 2,55
110-158 Clutch Lining 5,10
110-170 Engine Fan 5,55
110-172 Fan Hub 23,80
110-174 Fan Hub Lower Collet 3,85
110-175 Fan Hub Upper Collet 3,85
110-210 Servo Tray 10,65
110-211 Servo Tray Lower Mount 15,75
110-212 Servo Mounting Plate 3mm 1,30
110-214 Center Servo Mount 3,40
110-215 Outside Servo Mount 3,40
110-216 Left Servo Mount Support, G10 5,10
110-217 Cyclic Servo Pivot Support, G10 5,10
110-218 Right Servo Mount Support, G10 3,40
110-221 Cyclic Bell-Crank, Plastic 3,00
110-222 4x3.5mm Bell-Crank Spacer 1,30
110-223 4x26mm Threaded Spacer 1,30
110-224 4x13mm Threaded Spacer 1,30
110-225 Tail offset bell crank 12,75
110-226 Tail offset bell crank Block 10,20
110-227 Tail Pitch Servo Pushrod 2.5x4x280 4,70
110-228 Threaded Servo Horn Mounts, 2.5mm 2,15
110-229 Threaded Servo Horn Mounts, 2mm 2,15
110-310 Un lateral del chasis izq. o drcho. en G10 30,60
110-311 Front Frame Plate, G10 12,75
110-312 Frame Connector Block 17,85
110-313 Frame Support "X-Brace" 19,55
110-315 Engine Mount Center Block 38,25
110-316 Engine Mount Side Block 5,10
110-320 Landing Gear Strut/White 12,75
110-321 Landing Gear Skid Tube 8,50
110-322 Threaded Skid Tube Lock Down 2,55
110-330 Fuel Tank 5,10
110-331 Fuel Tank Stopper 3,85
110-332 Fuel Tank Clunk 3,40
110-333 Fuel Tank Clunk Hose 0,85
110-334 Fuel Tank Vent 2,35
110-342 Fan Shroud, Right 4,70
110-343 Fan Shroud, Left 4,70
110-345 Rear gyro sensor mount, molded 3,85
110-400 Canopy Fiber Glass 57,80
110-418 Canopy Rubber Grommet 3,00
110-420 Canopy Front Mount 12,75
110-422 Canopy Rear Stand Off 8,50
110-425 Canopy Thumb Screw 8,95
115-110 Main Boom Clamp 17,00
115-111 Tail rotor control rod 3x4.75x750 10,65
115-114 Tail rotor control rod guide 1,30
115-115 Tail rotor control rod bushing 1,30
115-117 Carbon Boom support 3.4x5.5x590 8,50
115-119 Boom support end plastic 2,55
115-121 Boom support front spacer 3,40
115-122 Boom support threaded spacer 2,55
115-125 Horizontal fin clamp, lower 12,75
115-126 Horizontal fin clamp, upper 9,35
115-130 Horizontal fin Carbon 2mm 4,25
115-135 Vertical fin Carbon 3mm 15,30
115-138 Vertical fin clamp 25,10
115-140 Tail Boom Aluminum/Black 17,00
115-210 15 Tooth bevel gear 21,25
115-211 Transmission output shaft 7,25
115-212 Trans. Output shaft bearing block 11,50
115-213 TT Coupler Housing 6,40
115-214 Plastic hex bushing 2,55
115-215 TT Hex coupler 15,30
115-216 Torque Tube 20,40
115-217 TT collar 6,40
115-218 TT Inner Bearing Ring 3,85
115-219 TT Outer Bearing Cup 3,85
115-221 TT rear coupler 15,30
115-310 Tail transmission case 39,55
115-311 Tail transmission case cap 12,75
115-312 Tail output shaft 10,65
115-313 Tail input shaft 10,65
115-315 Tail rotor bevel gear, Plastic 15,30
115-316 Tail rotor bell-crank 2,55
115-318 Tail pitch slider bushing 3,40
115-319 Pitch slider bearing ring 0,85
115-321 Tail Pitch plate 15,75
115-322 Tail pitch link 2,55
115-323 Tail rotor hub 15,30
115-324 Tail Rotor Grip 4,25
120-110 Head T-Block 55,25
120-112 Main Rotor Grip Plastic 12,75
120-113 Head Axle Sleeve 5,10
120-114 Head Axle 8,95
120-115 Head Button Plastic 2,15
120-116 Bell Mixer 19,15
120-118A Seesaw 15,30
120-119 Flybar Control Arm 19,15
120-121 Flybar Control Arm Stand Off 12,75
120-122 Swash Anti Rotation 3,85
120-125 Flybar, 5mm 8,50
120-213 Washout Arm Molded 6,80
120-214A Washout Link 2,55
130-050 Paddles SAB 3D 5mm 41,25
130-105 105mm Tail Blades SAB 27,65
200-110 Clutch Bell Assembly 34,00
200-115 Tail Gearbox Assembly 116,05
200-120 Main Rotorhead T-Block Assembly 83,75
200-148 Main Gear Hub Assembly w/BRG 30,60
200-149 Main Gear Hub End Cap Assembly w/BRG 20,85
200-160 Inline Clutch Assembly 36,15
200-210 Washout Hub Assmebly 23,40
200-216 Torque tube assembly 37,85
200-218 Swashplate Assembly 80,35
999-102 Decal 7,25
