unos mas
Turnigy nano-tech 460mah 3S 25~40C Lipo Pack
http://www.hobbyking.com/buddy.asp?code ... F378C032D8
hexTronik 24gram Brushless Outrunner 1300kv
http://www.hobbyking.com/buddy.asp?code ... 81AC0E9599
#1141035
Unos cuantos más:
Turnigy Servo Signal Reverser
http://www.hobbyking.com/buddy.asp?code ... 947FF7EAA3
Large Bore/Capacity Gas Filters (Grey) (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... D70A93C9B9
Twisted 80CM Servo Lead Extention (Futaba) 22AWG (5pcs/set)
http://www.hobbyking.com/buddy.asp?code ... B74E761B78
Front Wheel Steering Arm & Mount Set 32mm (5sets)
http://www.hobbyking.com/buddy.asp?code ... C927106B3D
Pivot & Round Hinges 4.5x67mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... EB64A3CB1D
Pivot & Round Hinges 2.5x43 (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 694A02C7FD
Última edición por Carlos Romero el Vie, 04 May 2012 13:20, editado 1 vez en total.
Por danzig483
#1141266
Hola más códigos
Hex locknuts M4 10pc
http://www.hobbyking.com/buddy.asp?code ... 11FCDEB597
Hex-nuts M2 10pc
http://www.hobbyking.com/buddy.asp?code ... 3787DAB6F0
Hex Fastener Nuts M3 (15pcs/bag) - 1/5 4WD B
http://www.hobbyking.com/buddy.asp?code ... 4969CB54B4
5.6mm x 21mm M3 Nylon Threaded Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code ... BEDE5C2CAB
5.6mm x 30mm M3 Nylon Tapped Spacer (10pc)
http://www.hobbyking.com/buddy.asp?code ... B76E2D46E1
Hobby King Quadcopter Power Distribution Boa
http://www.hobbyking.com/buddy.asp?code ... 4B0E4CD476
Por bonet
#1143362
Descuentos válidos hasta el 26-5-2012
Equilibrador de hélices.
http://www.hobbyking.com/buddy.asp?code ... BD86017622
Hélice tipo APC 11x5,5" slow eléctricos.
http://www.hobbyking.com/buddy.asp?code ... DD68EBF30B
Hélice 6x4" eléctricos
http://www.hobbyking.com/buddy.asp?code ... BC52DDC208
Carta programadora variador brushless HobbyKing BlueSeries Br
http://www.hobbyking.com/buddy.asp?code ... 33A0768F80
Espero que os sirvan y que pongáis los vuestros. :)
#1143387
Unos cuantos más:
Alloy Clevis for Non Threaded 2mm Control Rod
http://www.hobbyking.com/buddy.asp?code ... D9767D1346
Nylon Screws - Diam:4 x Length:34mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 03F3A18074
JR Y Servo Lead 30CM Length (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... AFAE7F4E7C
http://www.hobbyking.com/buddy.asp?code ... 6FD0E8998A
Luftwaffe 0.60~0.90 size Sheet A
http://www.hobbyking.com/buddy.asp?code ... 43AABDFFE8
#1144737
unos mas
5X3 Propellers (5Pcs/Bag)
http://www.hobbyking.com/buddy.asp?code ... C10100153F
JM 6x4 /152.5x102mm propeller (2pc/bag)
http://www.hobbyking.com/buddy.asp?code ... D8237ADB3A
Super Light Pivot & Round Hinges D2xW8xL24mm
http://www.hobbyking.com/buddy.asp?code ... 2B71E3273F
Control Rod/ABS Sleeve (1pc/bag)
http://www.hobbyking.com/buddy.asp?code ... AC2AB5C756
Super Light 5 Spoke Wheel D30xH7 (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 299D689E6A
Micro Clevis 1.2x22mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 4D95DCF7BB
JM 8x4 /203x102mm propeller (2pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 27D163DA87
TP Slow Fly propeller 8x3.8
http://www.hobbyking.com/buddy.asp?code ... A66D43C661
Hobby King 4.3g / .5kg / .10sec Micro Servo
http://www.hobbyking.com/buddy.asp?code ... 96668B68E1
#1145350
Unos cuantos más:
Alloy Fuel Tank Vent for Gas Models (Small Bore)
http://www.hobbyking.com/buddy.asp?code ... 6EC9F4AF4D
Alloy Fuel Dot for large scale Gas Planes
http://www.hobbyking.com/buddy.asp?code ... 1BCBA21A70
Fuel Tank Bung (Gas/Petrol)
http://www.hobbyking.com/buddy.asp?code ... 0A43F17C22
Metal Fuel Clip 3mm Pipe (5pcs/bag)
http://www.hobbyking.com/buddy.asp?code ... 3144520648
Turnigy 9X LCD Backlight Kit - Blue (DIY)
http://www.hobbyking.com/buddy.asp?code ... 987A2F8CEE
Fuel Dot Gas/Glow
http://www.hobbyking.com/buddy.asp?code ... 004F7D272B
Large Fuel Clunk with filter for Gas/Turbine
http://www.hobbyking.com/buddy.asp?code ... 52D073E59E
Por hastapronto
#1146034
Saludos a todos.
Este es mi primer mensaje. Espero que a alguien le sea de utilidad.
Aquí está mi lista de códigos: http://hk.rc-international.info/swarm/hastapronto
Y desglosados...
Magnetic screws/parts Tray
http://hk.rc-international.info/buddy/m ... tray-87085
Turnigy 760LV-HV Dual Pulse Width Selectable Servo Tester
http://hk.rc-international.info/buddy/t ... ster-87084
CNC Metal Transmitter Stand JR & Futaba
http://hk.rc-international.info/buddy/c ... taba-87083
TurboThumbs Super Big Futaba Rocker
http://hk.rc-international.info/buddy/t ... cker-87082
Training Gear for 450 Class Helicopter
http://hk.rc-international.info/buddy/t ... pter-87081
Button spirit level. (2pc)
http://hk.rc-international.info/buddy/b ... evel-87080
HK-171 Thread Locker & Sealant Medium Strength (Blue)
http://hk.rc-international.info/buddy/h ... ngth-87079
Turnigy Pinion Removal Tool
http://hk.rc-international.info/buddy/t ... tool-87078
Turnigy 4.7mm Ball End Reamer
http://hk.rc-international.info/buddy/t ... amer-87077
Turnigy 4mm Ball End Reamer
http://hk.rc-international.info/buddy/t ... amer-87076
Turnigy Ball End Driver for R/C Helicopters
http://hk.rc-international.info/buddy/t ... ters-87075
TURNIGY Voltage Protector
http://hk.rc-international.info/buddy/t ... ctor-87074
Estos códigos caducan el 31 de mayo.
Por malaga30
#1146431
pongo algunos:
http://hk.rc-international.info/swarm/wily27
FC 28-22 Brushless Outrunner 1200kv
http://www.hobbyking.com/hobbyking/stor ... C45B8EB1C7
Turnigy Pure-Silicone Wire 16AWG (1mtr) Red
http://www.hobbyking.com/hobbyking/stor ... DA20602EF3
Super Light Pivot & Round Hinges D2xW8xL24mm (12pcs)
http://www.hobbyking.com/hobbyking/stor ... 2C4C4C8CCD
Insta-Set CA Accelerator 2. oz
http://www.hobbyking.com/hobbyking/stor ... EC457CDB4E
NTM Prop Drive 3542 Series Replacement Shaft
http://www.hobbyking.com/hobbyking/stor ... 39BDB54A83
Por Lanius
#1146433
Buenas Malaga30, Los buddy codes son el link que aparece pinchando en el pedido en el icono que marco en la foto:
Por cierto, la pagina que pones de buddy codes esta muy bien! no la conocia.
Por malaga30
#1146435
si lo se.
el primer enlace sale todos los budy que tengo.
en los enlaces siguientes son de hobyking,si estas logueado te sale con el descuento,por lo menos a mi me sale bien,o me quieres decir otra cosa y no te entendido
Por Lanius
#1146438
Female XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/buddy.asp?code ... 3C24D686B6
Prop Saver w/ Band 4mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... DDF4C68CC3
Self Tapping Screws w/shoulder M2x8 (10pcs/s
http://www.hobbyking.com/buddy.asp?code ... 909A7FF88D
Control Horns 16x20mm (10pcs)
http://www.hobbyking.com/buddy.asp?code ... 7B5DBD2510
Male XT60 connectors (5pcs/bag) GENUINE
http://www.hobbyking.com/buddy.asp?code ... ED9F13B266
2.5x12mm Counter Sunk head Screw (10pcs/pack
http://www.hobbyking.com/buddy.asp?code ... CAA33E43F0
Por Lanius
#1146440
ah OK, el enlace de tus buddycode es el de arriba, ya lo pillo. Los enlaces de abajo son solo los productos, sin descuento. Por cierto he pillado otro motorcillo de 1200Kv xomo el tuyo con tu buddycode, gracias.... jejjeje
Por malaga30
#1146442
el primer enlace,son los budys con descuentos que tengo,los siguientes enlaces son de la tienda hobbyking,y si estas logueado te salen con el descuento directamente.
:D un motor pues eso que me llebo jejeje,eso que compren con mis budycodes :D .
gracias
Por tazoom
#1146933
Unos pocos mas:
Códigos extra
, Puedes guardar
13.88% Para todos estos productos
! Códigos de
RC-Buddy.com
Hextronik MG-14 14g/2.2kg/0.11sec aircraft servo
Ahorro
: 20.25 % / $1.61
Precio Final
: $6.34
Peso
: 25 g
Aluminum Spinner 89mm / 3.5 inches 3 Blade
Ahorro
: 12.44 % / $1.48
Precio Final
: $10.42
Peso
: 138 g
Hobby King Discovery Buzzer
Ahorro
: 12.93 % / $0.38
Precio Final
: $2.56
Peso
: 30 g
X8 R7 7Ch 2.4GHz Receiver (Short Antenna)
Ahorro
: 18.57 % / $5.19
Precio Final
: $22.76
Peso
: 90 g
Turnigy 2650mAh 3S 1C LLF Tx Pack (Futaba/JR)
Ahorro
: -0.7 % / $-0.09
Precio Final
: $12.88
Peso
: 175 g
Ahorro
: 36.36 % / $0.4
Precio Final
: $0.70
Peso
: 15 g
#1146957
algunos mas para depron
JM 6x4 /152.5x102mm propeller (2pc/bag) Muy buenas elices
2mm Gold Connectors 10 pairs (20pc)
http://www.hobbyking.com/buddy.asp?code ... EDE52D5BFE
Por Currante
#1147514
Aqui dejo codigos de descuento para quien le interese
HK450V2 Stabilizer Bar
http://www.hobbyking.com/buddy.asp?code ... E6B166B2C7
HK450V2 Tail Rotor Control Set
http://www.hobbyking.com/buddy.asp?code ... 40C2C75FA9
HK450V2 Tail Blade
http://www.hobbyking.com/buddy.asp?code ... FD9AC8F0EB
On Board Lipoly Low Voltage Alarm (2s~4s)
http://www.hobbyking.com/buddy.asp?code ... DD9C8005B3
Le quedan 14 dias
Por san
#1147737
Otros mas, le quedan 15 dias:
SF E-Prop 10x3.8 / 254x96.5mm w/ Adapters Bl
http://www.hobbyking.com/buddy.asp?code ... BB17E0E212
SF E-Prop 8x3.8 / 203x96.5mm w/ Adapters Bla
http://www.hobbyking.com/buddy.asp?code ... 5F89E9116E
http://www.hobbyking.com/buddy.asp?code ... 7E0355CA4C
http://www.hobbyking.com/buddy.asp?code ... C7C9B1E149
Futaba Transmitter Neck Strap
http://www.hobbyking.com/buddy.asp?code ... E51B4F0D9F
http://www.hobbyking.com/buddy.asp?code ... 37A056BCAE
Por hastapronto
#1148278
Saludos a todos.
Más compras en Hobbyking. Espero os sean de utilidad. Son válidos hasta el 16 de Junio
Y desglosados...
Main Rotor Blade Assembly Tool (5mm)
http://hk.rc-international.info/buddy/m ... tool-89059
Head Stopper for 450 Size Heli
http://hk.rc-international.info/buddy/h ... heli-89060
Heli Canopy Rubber Grommet Small (6pcs/bag)
http://hk.rc-international.info/buddy/h ... mall-89061
Carbon Fiber Tail Blade 68mm
http://hk.rc-international.info/buddy/c ... 68mm-89062
Turnigy 4mm Heat Shrink Tube Yellow (1mtr)
http://hk.rc-international.info/buddy/t ... llow-89063
Strong Rare-earth Magnets (10pcs/set)
http://hk.rc-international.info/buddy/s ... nets-89064
Transmitter Neck Strap Balancer (Futaba)
http://hk.rc-international.info/buddy/t ... ncer-89065
Turnigy 5mm Heat Shrink Tube -
[/URL
Turnigy 5mm Heat Shrink Tube - BLACK (1mtr)
[url=http://hk.rc-international.info/buddy/t ... lack-89067]http://hk.rc-international.info/buddy/t ... lack-89067
Turnigy 4mm Heat Shrink Tube -
http://hk.rc-international.info/buddy/t ... ube--89068
Turnigy 4mm Heat Shrink Tube - BLACK (1mtr)
http://hk.rc-international.info/buddy/t ... lack-89069
TURNIGY 3A UBEC w/ Noise Reduction
http://hk.rc-international.info/buddy/t ... tion-89070
  • 2
  • 3
  • 4
  • 5
  • 6
  • 13
